Author Topic: feedback to text file  (Read 12110 times)
« on: June 20, 2012, 19:32:32 pm »
Hello All,
Someone know how to redirect or copy the data displayed in the status windows to a text file (as a log file) ?
The goal is to obtain a list of MOP and their machining time ; currently I do a screen capture of the status window, but its not as usable that a text file.
Online pixelmaker
Re: feedback to text file
« Reply #1 on: June 20, 2012, 20:51:21 pm »
hello David,
no way to print it out. And I found no way to copy this text.
I ask for this feature last year.
I would like to print or copy it to to compare the machining times when I do changes in the mop. I do a screenshot now and print it out.
« Reply #2 on: June 20, 2012, 22:08:28 pm »
Hello Ralf,
Yes I remember that you ask for this feature.
I try to access to the window by vbscript, but I can only write in it, I can't found how to get the existing data in the window.
« Reply #3 on: June 20, 2012, 22:18:20 pm »
Is there an "error channel" in the language Andy uses?
In 'IX programming, I was always able to re-direct errors to a log by redirection of the error channel.
Online pixelmaker
« Reply #4 on: June 20, 2012, 22:49:46 pm »
hello David,
I can´t do this in vbscript. I dont know the syntax. Please show me script  that I can see how you write into the window.
May I can help for this without learning vbs.
« Reply #5 on: June 21, 2012, 17:46:21 pm »
Hello Ralf,
It's not really a syntax problem, VB keywords and functions can be found on MSDN, but a lack of infos about Cambam specific functions. Only Andy can deliver info about that ....
I did not much tired to find it lol! :-[
this is the one that appears by default when creating a new script
' New CamBam VBScript
sub main
app.log("Hello")
end sub
It writes "Hello" in the bottom windows
« Reply #6 on: June 21, 2012, 19:36:32 pm »
Sorry for the lack of progress on this one... It hasn't been forgotten, it just got pushed a bit down the priority list.
I was intending a significant rewrite of the message logging, but there is something we can do in the meantime.
I have attached a plugin for you (unzip to the plugins folder).
This adds a new Plugins menu item : MessageLog Copy
When selected, all text in the message log will be copied to the clipboard.
I hope this helps!
« Reply #7 on: June 21, 2012, 21:23:04 pm »
Hello Andy,
Yes !! very thanks that help well  ;)
Now I can do a VB tools that extract and sort the data that I want from the copied file.
I've a file with 34 Mop that I must optimize, to reduce machining time for mass production.
good night
Offline Tool-n-Around
« Reply #8 on: August 11, 2021, 12:42:21 pm »
Hi David, will this plugin copy the text as displayed in the GRBL Machine plugin message window?
Best,
Kelly
« Reply #9 on: August 11, 2021, 13:12:53 pm »
I don't think so ... but I can't use GRBL plugin, so I don't know where its messages are written ; if they are written in the "regular" cambam log message window they should be copied, but if it's a window specific to the plugin, they will not be.
