With David's (dh42) help, I've found a bug that would not occur on my machines. This 3.1.1.3 version seems to work pretty well. Enjoy... still report problems, please.
And finally, V3.2.0.0 with printer selection, gray-scale conversion, and sticky capture options.
For capturing 3D images, and especially if you convert to monochrome, you should experiment with background and layer colors, as no one conversion 'formula' suits all needs.
And the translatable version source, here now.
L
0-0
The attached is the 'crude' print with various improvements and some finer clothes.
It automatically saves a full-screen capture AND a cropped, scaled, rotated capture image to the folder from which the CamBam file was opened. If it is used on a never-saved file, those files are saved to the system.temp folder.
It will: Fix colors so that printing may be done economically on white paper
Capture and print either a full-screen image or a user-selected rectangle from the screen
Scale the image for best fit to the paper source in the printer
Rotate the scaled image for best fit on the paper.
It prints only the the current default printer. The images are saved as native bitmap files (.bmp).
Just unzip the attached file, and copy the .dll to your CamBam ProgramFiles/Plugins folder, the re-start CamBam.
If you tried the original V1.0.0.0, be sure to remove that .dll from your plugins folder!
Enjoy.
