Author Topic: help converting to DXF  (Read 4809 times)
Offline chadrat6458
« on: August 15, 2016, 12:59:47 pm »
My friend gave me this jpeg file. I tried converting it but it did not look that great. Can someone help me convert it to a good DXF file? What would be the best way to cut this? Engrave? Thanks.
Re: help converting to DXF
« Reply #1 on: August 15, 2016, 13:09:02 pm »
DXF attached
Offline chadrat6458
« Reply #2 on: August 15, 2016, 13:43:59 pm »
Thanks. Is there a way to smooth out the lines?
« Reply #3 on: August 15, 2016, 15:00:33 pm »
A smoother shape in attachment
I use this method
In the case of you drawing, the first think to do is to "remove overlaps", because all shapes exist twice (superimposed)
http://www.cambam.info/doc/dw/0.9.8/cad/EditPolyline.htm
« Last Edit: May 17, 2021, 21:17:20 pm by dh42 »
Offline chadrat6458
« Reply #4 on: August 16, 2016, 02:55:11 am »
Is there a good freeware program to convert jpeg to dxf?
Offline dwc
    • corson.ch
« Reply #5 on: August 16, 2016, 13:13:23 pm »
In my experience it is always quicker to trace by hand.
The auto tracers create such junk that one needs more time to correct what they do than to do it right by hand.
Don
Offline chadrat6458
« Reply #6 on: August 16, 2016, 13:28:48 pm »
That might be what I need. What do you need to trace it by hand?
« Reply #7 on: August 16, 2016, 14:59:02 pm »
Inkscape does a mediocre job of tracing outlines.  I've used it for complex logos where the minor jagged ness doesn't seem to matter.  It still requires quite a bit of cleanup.
For monochrome bitmaps I've had as good of luck as anything with using CamBam.
http://www.youtube.com/watch?v=PkM5h6gQ7oA
Offline chadrat6458
« Reply #8 on: August 16, 2016, 15:39:57 pm »
Thanks Bob, I will try that.
