Author Topic: Draw Centre Lines plugin  (Read 6814 times)
« on: July 27, 2017, 08:55:34 am »
In response to this thread; http://www.cambam.co.uk/forum/index.php?topic=6737.msg54555#msg54555
This plugin draws centre lines for Rectangles, I plan to add circles soon and circles
It will appear in the 'Draw' menu as 'Centre Lines'
Just select one rectangle or circle then run the plugin.
It should work on CamBam 0.9.8. and 1.0
I had to go on a detour to get this working due to the transformations not being applied to rotated objects etc.
Edit: version 2 attached
1. works with rectangles and circles
2. translation added for message box
3. undo points added
« Last Edit: July 27, 2017, 11:31:48 am by EddyCurrent »
Re: Draw Centre Lines plugin
« Reply #1 on: July 27, 2017, 15:22:38 pm »
Lest we forget, they can also be converted to dashed lines  ;D
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Dashed_Lines.html
And if you use the 'Groups' plugin they can become as one object making for easy manipulation.
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Groups.html
« Last Edit: July 27, 2017, 15:31:34 pm by EddyCurrent »
« Reply #2 on: July 27, 2017, 16:51:55 pm »
Lest we forget, they can also be converted to dashed lines  Grin
+1
Here's to you Eddy!! ;D ;D ;D
« Reply #3 on: August 05, 2017, 20:19:19 pm »
Many thanks Bubba.
I've attached the VS source project files
« Reply #4 on: August 06, 2017, 00:48:28 am »
Many thanks Bubba.
Don't need to thank me. You did all the work! :D
