Author Topic: Halftone image generator plugin - "Semitone"  (Read 26988 times)
« on: October 26, 2017, 17:45:59 pm »
I thought it was about time we had a halftone image plugin.
Please find attached version 1, works with CamBam v0.9.8 and v1.0
Test image also attached.
Once installed it appears in, Plugins->Semitone
Request !
How can I make the custon script in the drill MOp modal for R and F ? (look at the g-code sample)
M3 S16000
G0 X0.0 Y0.0
G98
G81 X0 Y0 Z-0.309295 R3 F300
G81 X5 Y0 Z-0.61859 R3 F300
G81 X10 Y0 Z-0.309295 R3 F300
G81 X15 Y0 Z-0.309295 R3 F300
G81 X20 Y0 Z-0.309295 R3 F300
G81 X25 Y0 Z-0.61859 R3 F300
G81 X30 Y0 Z-0.309295 R3 F300
G81 X35 Y0 Z-0.309295 R3 F300
Edit: Version 1.11 attached
1. buttons added to change foreground and background colours of simulation
Edit: Version 2.1 attached
The gcode will have to stay as above for now.
See this post for what's new, http://www.cambam.co.uk/forum/index.php?topic=6927.msg56554#msg56554
Edit: Version 2.2 attached
See this post for what's new, http://www.cambam.co.uk/forum/index.php?topic=6927.msg56556#msg56556
Edit: Version 2.3 attached
fixed a crash bug with some images.
Edit: Version 3.0 attached
Spiral method added, the centre can be located anywhere in the frame.
Picture shows output in CutViewer
Edit: Version 3.1 attached
Lines method added.
« Last Edit: November 10, 2017, 11:32:58 am by EddyCurrent »
Re: Halftone image generator plugin - "Semitone"
« Reply #1 on: October 26, 2017, 19:21:28 pm »
Eh... I don't think they can BE modal in the PP.  A quick-n-easy PBP would fix it, though!
« Reply #2 on: October 26, 2017, 19:23:58 pm »
Thanks, that's what I thought
« Reply #3 on: October 26, 2017, 19:34:00 pm »
Okay I tried it with .NET 3.5 and it works, so the attached version in the first post is okay for CamBam v0.9.8 and v1.0
Also I forgot to mention I have not tried it for real yet ! but I hope to tomorrow
« Last Edit: October 26, 2017, 19:36:52 pm by EddyCurrent »
« Reply #4 on: October 26, 2017, 23:17:40 pm »
Hi Eddy
This is a snippet from cnc-cookbook
Multiple Holes Until G80 Cancels the Cycle
As mentioned, these drilling cycles are modal. That means you can just real off a bunch of XY coordinates once the cycle is initiated, and the machine will happily execute the cycle at each location. To cancel the cycle, use G80. After executing the G80, the machine returns to G00 mode
so the R value is modal but the feeds are determined by the type of drilling operation "G-somevalue" there are a few of these to choose from.
« Reply #5 on: October 27, 2017, 01:58:49 am »
Very nice !
Thanks for this new plugin !
« Reply #6 on: October 27, 2017, 07:34:11 am »
Hi Eddy
Dave,
If a CamBam Canned Cycle Drill MOp is used, the R and F values are modal but it seems that when a custom script is used they are not.
« Reply #7 on: October 28, 2017, 02:09:49 am »
Hi Eddy
Have a look in the GRBL pp were Andy wrote code for this, GRBL doesn't know about canned cycles.
I can't remember the details but it may give you some useful info.
edit Nice plugin BTW.
« Reply #8 on: October 28, 2017, 03:56:22 am »
Hi Dave
It will be, Is that what you're talking about?
https://github.com/garciasa/grbl-drills-cambam
« Reply #9 on: October 28, 2017, 09:24:13 am »
HI Armando
No I Hadn't seen that one,but it may be useful, I was talking about a thread here.
« Reply #10 on: October 28, 2017, 15:01:49 pm »
Just playing now  ;D
Background and foreground colours for the simulation can now be changed, click the coloured buttons on the form to change.
Version 1.1 attached to first post.
Also keep this in mind !
The depth calculations are based upon a V cutter coming to a sharp point of zero diameter but in practice this may not be the case.
As the tool will be zeroed to it's tip, the maximum hole diameter may therefore be exceeded when cutting on the machine.
« Last Edit: October 29, 2017, 09:24:53 am by EddyCurrent »
« Reply #11 on: November 01, 2017, 10:55:59 am »
hello Eddy
thank you for this plugin. I use the old Haftoner for this work.
Perhaps in one future version it is possible to change the grid angle.  ;D
A grid angle of 41° looks best. It is the angle that is used for color black in print separation.
Ralf
Online Dragonfly
« Reply #12 on: November 01, 2017, 13:27:11 pm »
Hi Eddy, nice idea in that plugin.
Besides the dot raster there is also a linear one - parallel lines with varying width. Usually at an angle different from vertical and horizontal. This way the tool does long stokes with varying depth. Much like the heightmap generation but there are many (resolution defined) parallel lines and the user can control the angle.
The same technique is used for pressure engraving on stone or other hard materials. A diamond coated ball bit is used and instead of real Z movements a variable pressure is applied.
I've been, for a long time now,  planning a pressure engraving adapter which will convert Z step commands into PWM voltage applied to a coil.
« Reply #13 on: November 01, 2017, 13:48:51 pm »
Dragon,
Why not just use a spring loaded tool where Z depth compresses spring to different pressures? Spring rates are in force per compression distance. So you might have spring that has 100 lbs per inch rate. A Z of -.5 would produce a 50 lb force.
Online Dragonfly
« Reply #14 on: November 01, 2017, 17:55:44 pm »
I have made some experiments with a spring but with no good result. Besides, what I have seen as working designs do not use springs. The forces are not that great.
The tool is driven by a small high rpm motor similar to those of small grinders like Dremel. The spindle axis is at an angle to the material surface to provide sufficient peripheral speed. The force is generated either by an electromagnet or a DC motor which is not rotating but rather producing variable torque. There is a spring but is lifts the tool when no voltage is applied.
I think such solution is easier to tune than a mechanical spring one and can modulate the force at higher rates.
