Resources => Scripts and Plugins => Topic started by: dh42 on September 24, 2015, 20:03:19 pm
This script is designed to remove points closest to the given value in a polyline.
it's an experiment to clean the polylines that results of a picture digit (to remove the stairs)
' remove points closest to the given value
Sub main()
Dim rep As String
Dim tol As Double
Dim p As polyline
Dim nbpt1 As Integer
CamBamConfig.Defaults.ReloadTreeAfterScript = False
rep = inputbox("Max distance between 2 points", , 0)
tol = val(rep)
If CamBamUI.MainUI.ActiveView.SelectedEntities.Length > 0 Then
For Each ent As Entity In CamBamUI.MainUI.ActiveView.SelectedEntities
If TypeOf ent Is Polyline Then
p = ent
CamBamUI.MainUI.UndoBuffer.AddUndoPoint("RemovePoints")
CamBamUI.MainUI.UndoBuffer.Add(ent)
nbpt1 = p.Points.Count
If p.RemoveDuplicatePoints(tol) = True Then
App.Log("Polyline: " & ent.ID & " #Points before: " & nbpt1 & " #Points after: " & p.Points.Count & " #Points removed: " & nbpt1 - p.Points.Count)
End If
p.Update()
End If
Next ent
CamBamUI.MainUI.ActiveView.RefreshView()
End If
End Sub
