Hi Kelly
There are some threads here about this subject (file exchange formats), it’s a tin of worms.
We can import .dxf, .stl and step files.
For what you want to do it’s not worth the effort to use step files, as they require you to know
a fair bit about (exchange formats) to get a reasonable result. I use them because I’m making
engineered components in 2.5D, ‘3D’ won’t cut it for the accuracy required.
The step file format has an Industry standard. NIST.
I don’t know about Alibre, It has a somewhat checkered history, that software has been bought
and sold a few times, but even things like Freecad have an export preferences page and many tools to work
with repair and reduce the file size as part of the Mesh workbench. The STL format is old but it’s it’s an open
standard, newer programs are transitioning to AMF (the 3D printing crowd are all over it) which is better in every way.
In short use a stl and dig around in Alibre to find the working with mesh’s doc.
Some programs like Prusa slicer (free) will automatically on loading the file repair it
and on occasions I’ve had a stl file that I could not fix and running through the slicer
it was repaired. Alibre may already do this, I don’t know.
It’ll be a matter of trial-and-error finding what works best for you, just reduce the stl
triangle count until it’s not usable in CB (you’ll get to much faceting) especially for waterline tool paths
and then start raising the count until the file is ok for CB. I’ve included a pic hopefully showing what I
meant about the resolution you can expect with a 6mm and 4mm tool, as there is no point having a model
with huge resolution if the tools won’t allow you to achieve it.
