Author Topic: the contact form does not work  (Read 22048 times)
« on: November 18, 2022, 11:55:31 am »
Hello David
There is an incorrect configuration for the contact form. It is an error with the name servers. The emails are then rejected from the recipient address.
Final-Recipient: rfc822;10bulls@gmail.com
Action: failed
Status: 5.5.0
Diagnostic-Code: smtp;550-5.7.25 [95.128.15.162] The IP address sending this message does not have a
550-5.7.25 PTR record setup, or the corresponding forward DNS entry does not
550-5.7.25 point to the sending IP. As a policy, Gmail does not accept messages
550-5.7.25 from IPs with missing PTR records. Please visit
550-5.7.25  https://support.google.com/mail/answer/81126#ip-practices for more
550 5.7.25 information. f20-20020a67d894000000b003acd356f398si569801vsj.561 - gsmtp
Re: the contact form does not work
« Reply #1 on: November 18, 2022, 14:33:12 pm »
Hello Ralf
I received Lothar's message on the support, and I just reply, so seems there is no problem with the support (except that I can't retrieve his license  edit: Ok found under another mail address, I just sent it back)
Cambam support mail is
support@cambamcnc.com
« Last Edit: November 18, 2022, 14:53:04 pm by dh42 »
« Reply #2 on: November 18, 2022, 16:27:20 pm »
The contact form still needs to be fixed. It is at https://cambamcnc.com/contact but sends via the MTA: cambam.co.uk .
This looks to G-Mails as if the mail form is being misused. This is some cheap Java script code. Only the processing server has to be changed.
« Reply #3 on: November 18, 2022, 17:04:15 pm »
Re
I'll point this post to Andy because I don't understand anything  ;D
« Last Edit: November 18, 2022, 17:06:00 pm by dh42 »
