Author Topic: Reinstall CAMBAN and the serial number/key seems wrong  (Read 5451 times)
Offline WireCut
« on: November 26, 2022, 09:10:14 am »
I have reformatted the PC and I re-install CAMBAM.
Is installed:
CamBam plus [1.0] x64
Copyright © 2020 HexRay Ltd
CamBam.CAD : 1.0.7389.20585
CamBam : 1.0.7389.20589
Build Date : 25/03/2020 11:26:10
Evaluation Copy : 36 evaluations remaining
I insert the key but is not acceped.
Any suggestions?
BR
Leo
Re: Reinstall CAMBAN and the serial number/key seems wrong
« Reply #1 on: November 26, 2022, 16:06:21 pm »
You must run CamBam as administrator for the license key to be accepted.
https://cambamcnc.com/support/FAQ.aspx#2
Did you try to use the license file instead to type the key ?
Offline WireCut
Re: Reinstall CAMBAN and the serial number/key seems wrong - SOLVED
« Reply #2 on: November 26, 2022, 23:52:50 pm »
Hi David,
many thanks for your suggestion.
Running CAMBAM as administrator, the license key is accepted.
 :) ;) ;D
Ciao
Leo
