Author Topic: Getting started with plugins in Win10  (Read 11770 times)
Offline billo
« on: January 09, 2023, 15:13:56 pm »
I'm trying to create a plugin for CamBam Plus 1.0 in VS2019. I'm using the code from the tutorial: http://www.cambam.info/doc/api/CreatingAPlugin.htm
As recommended, I used the link in: http://www.cambam.info/downloads/ to install Framework 4.
That installs .Net Core 3.1, which supposedly contains many legacy frameworks, such as Framework 4.
Now when starting a new Project in VS2019, the Target Frameworks presented as options include: .Net Standard 2.0, and .Net Core 3.1. I chose .Net Core 3.1.
My first compile complained that System.Drawing.Common is not available. Reading online I see that adding that package with NuGet is the solution. The oldest version available was 4.5. I downloaded that and added it as a reference.
Now it compiles without errors or warnings.
I copied my plugin .dll and System.Drawing.Common to the plugins folder.
Upon starting CamBam I get the message: Could not load file or assembly 'System.Runtime, Version=4.2.1.0, Culture=neutral, ...
I've used VS for 2 decades, but never with a mix of older components like this; so I am unfamiliar with assembly redirects and such.
Does anyone have advice on how to proceed?
Tia,
Bill
Re: Getting started with plugins in Win10
« Reply #1 on: January 10, 2023, 21:52:02 pm »
Have a look here;
This is a sample plugin
https://cambamcnc.com/forum/index.php?topic=6668.msg53974#msg53974
This is a list of useful tools ( some of the links may be bad now)
https://cambamcnc.com/forum/index.php?topic=4904.msg37372#msg37372
With ILSpy you can see the code for all plugins listed here; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/plugin_menu.html
