But Bob, regardless of which method you use to remove less material per pass of the tool, the end result is the same -- it takes the same amount of time!
You can use a trochoidal MOp, and reduce 'engagement' by that means, or you can use ordinary profile MOps, and reduce the engagement deliberately through 'feeds-n-speeds' and depth-of-cut management. The only benefit of a trochoidal MOp is that you can use 'full depth' of the tool, but at the expense of a wider cut, meaning more material has to be removed for a given profile.
Maybe I should have put that in bold, supercaps! Sheesh!
