Author Topic: MOVE, PAUSE, WAIT for my input  (Read 17710 times)
Offline jimmer
« on: April 17, 2023, 16:03:16 pm »
I want the machine to move away from the last operation, then pause whilst I check the work, then start up again when I click something.
Also I prefer not to have to call code in an external file (insert gcode).  And I want it all done by a single mop (MOVEPAUSE). I'd be quite happy if I could just write some GCODE directly into a mop.
At the moment I'm about do it by inserting a dummy drill mop at the out of the way location with a different tool. So I'm expecting to have to press GO before it moves away and then before it resumes operation. This seems pretty good because I don't need to know the GCODES the only downside is that I have to ensure the drill operation doesn't cut anything (not too difficult!).
Any other ideas?
I've not used my machine for a while, and feeling a bit anxious about trying new things LOL.
Cambam. Mach3. USB motion controller. 1800x950 ballscrew router, vacuum bed, 3kW spindle.
Re: MOVE, PAUSE, WAIT for my input
« Reply #1 on: April 17, 2023, 16:12:39 pm »
maybe you can insert GCode in the "Custom Mop Footer" property
Some G0 to move the tool away and a M0 to do a "pause"
« Reply #2 on: April 17, 2023, 20:47:23 pm »
Issue an extra G4 toolchange to the same tool you're using.  It will wait for you to 'change the tool', and proceed after hitting Enter.
« Reply #3 on: April 17, 2023, 21:15:12 pm »
I think a more specific process in the MOP footer like below would be more suitable.
M5 M9
G53 Z(clearance) 0R G0 Z(clearance)
G0 X(x)Y(y)
M0
M3
Some controls may require you to set M0 in configuration and others may use G53 in very specific ways.  In others you may be able to use G28 or G30, but I would not.  Their exact implementation varies.
« Last Edit: April 17, 2023, 21:18:12 pm by Bob La Londe »
Offline airnocker
« Reply #4 on: April 17, 2023, 23:19:06 pm »
I like jimmer's question as it seems like a useful thing to know and be able to do.
But, I don't see any "Custom MOP Footer"  property in any MOP properties in CB1.0.
I see a "Custom File Footer" in the Machining Object but don't see how that apply to a specified MOP.
What am I missing?
airnocker
« Reply #5 on: April 17, 2023, 23:46:19 pm »
What am I missing?
glasses ?  ;D ;D
« Reply #6 on: April 17, 2023, 23:56:40 pm »
What am I missing?
glasses ?  ;D ;D
It doesn't show if viewing BASIC MOP properties.  It does show in advanced.
Offline airnocker
« Reply #7 on: April 18, 2023, 01:03:22 am »
Drum roll, please.  Ta-da!
Thanks.  I see it now.
airnocker
