Author Topic: Delete - Restore Stock plugin  (Read 10375 times)
« on: May 18, 2023, 21:46:21 pm »
This plugin allow to delete and restore the current stock definition. (only the main stock in the machining folder)
Two items are available in the plugin menu.
- Delete Stock > store the datas of the current stock in memory, then erase all stock data (except the colors)
- Restore Stock > restore the erased values. This item is disabled until a stock as been erased with Delete Stock.
for CamBam 1.0 only ; not tested on linux nor on Windows 64bits version of CamBam, feel free to give some feedback if you test it on one of this versions.
Re: Delete - Restore Stock plugin
« Reply #1 on: May 19, 2023, 08:36:19 am »
Works fine with 64bits.
« Reply #2 on: May 19, 2023, 09:58:29 am »
Thank you for this plugin David.
« Reply #3 on: May 19, 2023, 15:48:52 pm »
Even if this is not the goal of this plugin, it can also be used to copy a stock from a project to another.
- on the source project, delete then restore the stock so it is saved into the memory.
- without closing CamBam, open the file where you want to copy the stock (or a new blank file), then use "restore" to get a copy of the copied stock in the new file.
« Reply #4 on: May 27, 2023, 21:54:36 pm »
I finally had a need for it again and tested it.  I've been up to my back side in alligators the last couple weeks or I would have tested sooner.  Equipment problems, vendor problems, mostly just me problems.  I apologize for not trying this sooner.  Especially since you went to the effort to create it for me.
I notice two things.
Not related to the plugin:  If stock is set in a part then setting the values to zero DOES set the stock to undefined unlike setting the stock values in the machining parameters.
About the plugin:  The plugin works perfectly on only the machining parameters for stock.  I am running 64bit CamBam.  No bugs noted so far.
Thank you, and again I apologize for not trying it and giving feedback sooner.
