Author Topic: How to handle multiple objects in an STL file  (Read 8496 times)
Offline billo
« on: May 22, 2023, 18:16:51 pm »
I am exporting multiple individual objects from Rhino to an .stl file. When I open it in CamBam, the objects are not individually selectable. That is all Rhino objects are combined into one object in the .stl.
I typically have up to 50 such objects that need to be cut on multiple sheets of stock, so it is important that I create toolpaths accordingly.
I have read that .stl does not support multiple objects in a single file.
I see a number of different possibilities:
* Try to break up the objects from within CamBam.
* Export to 50 individual .stl files from Rhino, then write a script to import them all into a single CamBam document.
* Export to .3mf, which is apparently an stl-like format that support multiple objects. Then figure out how to import this into CamBam.
Can anyone suggest additional options?
tia, Bill
Offline billo
Re: How to handle multiple objects in an STL file
« Reply #1 on: May 22, 2023, 22:58:22 pm »
Update: I'm trying 3D Studio (.3ds) format now. Rhino exports OK (but seems lo-res). CamBam loads the file as separate objects.
I'm still experimenting, but so far, the toolpaths don't look good.
Bill
« Reply #2 on: May 23, 2023, 09:23:44 am »
Here's two though not great.
1. Import the combined stl to CamBam, select it then use menu item, Edit->Explode
You will end up with a lot of small surfaces. Now select one of the 50 stl obects on the screen by dragging over it then use menu item, Edit->Join, repeat 50 times.
2. Export from Rhino as individual files then use this plugin to import them one at a time; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/import_DXF-STL-STP.html
I find it odd that you are using stl files, these are for 3D operations, can't you find a way to use 2D operations then use DXF files ?
Are all 50 objects the same ? if so you should look at using "Nesting" within Cambam then you only need to import one object.
« Last Edit: May 23, 2023, 09:27:19 am by EddyCurrent »
Offline billo
« Reply #3 on: May 23, 2023, 21:10:01 pm »
They are all 3D objects and they are all different.
I'm finding that 3DS format does what I want, but I am not getting the resolution I want from Rhino. I have to study the export options to see if I can get a better export.
Bill
Offline billo
« Reply #4 on: August 30, 2023, 18:23:14 pm »
Update: My solution was to export individual files from Rhino (using a script), and then import each of them into CamBam (using a script).
Works perfectly, although it took a while to perfect the scripts.
Bill
