Author Topic: Remove Stairs (VBS Script)  (Read 6845 times)
« on: May 26, 2023, 20:54:37 pm »
This VBS script remove on point on two on the selected polylines, this remove the "stairs" effect resulting of a bitmap digitizing.
Simple but efficient ;)
Prior to use it, create a new layer so the new created polylines can be easily separated from the source polylines.
' Remove stairs (for digitized images)
' scan all selected polylines and remove one point on two
sub main
        Dim p As Polyline
        Dim p2 As Polyline = New Polyline 'temporary polyline
        Dim toggle As Boolean = False
        Dim pt As Point3F
        If CamBamUI.MainUI.ActiveView.SelectedEntities.Length > 0 Then 'if something selected
            For Each ent As Entity In CamBamUI.MainUI.ActiveView.SelectedEntities 'scan all selected entyties
                If TypeOf ent Is Polyline Then 'reject other than polyline object
                    p = ent
                    For Each p_item As PolylineItem In p.Points 'scan the point item list
                        If toggle = True Then
                            pt.X = p_item.Point.X
                            pt.Y = p_item.Point.Y
                            pt.Z = p_item.Point.Z
                            p2.Add(pt)
                            toggle = False
                        Else 'item ignored
                            toggle = True
                        End If
                    Next
                    If p.Closed = True then
                        p2.Closed = True
                    else
                        p2.Closed = False
                    End If
                    Doc.Add(p2.Clone)'add a clone of the temp polyline to the document
                    p2.Points.Clear()' erase the temp polyline
                End If
            Next ent
            CamBamUI.MainUI.ActiveView.RefreshView()
        End If
end sub
edit:
an example
(PS: VB script does not works on 64bits versions of CamBam)
« Last Edit: May 31, 2023, 19:24:00 pm by dh42 »
