Author Topic: Changing pocket dimensions  (Read 11355 times)
Offline gld
    • GLD
« on: June 21, 2023, 14:05:12 pm »
I created a pocket1 a circle. The pocket was a little too small. So I increased the diameter by .100" .  It will not generate a new tool path.
I've changed other parameters and got a new tool path.
So do I need to create new mop and enter all parameters manually?
I tried copy & paste, that didn't work either.
So just changing primitive ID's is not allowed either?
« Last Edit: June 21, 2023, 17:54:40 pm by gld »
Gary
Windows 7 & 11
Alibre Design Pro V28
IntelliCADPro6, CamBam, Mach4
15" South Bend, 10" Logan lathe, Grizzly square column mill, Home built CNC router & Hot wire cutter.
Lagun FTV-1 knee mill, Sherline mill & lathe
3D Printers, Cetus, Anet ET5 X
Re: Changing pocket dimensions
« Reply #1 on: June 21, 2023, 15:41:10 pm »
You need to attach your cb file here otherwise everybody is just guessing.
The things you describe should work so that's why your file with all the settings is required for testing.
Offline gld
    • GLD
« Reply #2 on: June 21, 2023, 17:56:50 pm »
Every thing worked fine until  I changed the diameter.
Sorry, thought it would be a simple answer.
« Last Edit: June 21, 2023, 17:59:06 pm by gld »
Gary
Windows 7 & 11
« Reply #3 on: June 21, 2023, 18:33:31 pm »
It probably is a simple answer. Post your CB file so we can see.
Offline gld
    • GLD
« Reply #4 on: June 21, 2023, 19:28:56 pm »
It's in post #1
Pocket 2 has the same problem. I modified polyline 9. Then changed the primitive ID to match. it won't generate code either.
« Last Edit: June 21, 2023, 19:35:01 pm by gld »
Gary
Windows 7 & 11
« Reply #5 on: June 21, 2023, 20:27:59 pm »
Here you go.
I needed to change the tool numbers in order for the simulator to display correctly. The tool dia is the same .25".  Changed couple of things so please don't use it as is. Best to as an example and go from there. You did have MOP 2 , 5  disabled, it appears that was the issue.
Offline gld
    • GLD
« Reply #6 on: June 21, 2023, 21:22:59 pm »
Sorry guy's, I posted the wrong file. That was the one I was working on yesterday. Loaded  it up this morning and  deleted pockets 4&5, fixed tool # and still no tool path.
Then the light came on. I had the mops  disabled. DAM!! DAM!! DAM!! DAM!!
Any way, thanks too all for trying to help. I just don't use this program enough, and I'll be 82 in November and CRS is hitting me hard it seems.
Thanks again and have a good day.
P.S. It's all working now.
Gary
Windows 7 & 11
« Reply #7 on: June 21, 2023, 22:44:39 pm »
I have that problem.  If I forget to plug in the fridge I have to drink my beer warm too.
« Reply #8 on: June 22, 2023, 13:20:47 pm »
Join the club BOYS. I be 74 at the end of July.  :(
« Reply #9 on: June 25, 2023, 21:58:16 pm »
Hope I can still CNC at 82, I'll be 70 in two weeks.
