Author Topic: SOLVED - Motion command target is invalid on xPro V5 controller  (Read 15946 times)
Re: SOLVED - Motion command target is invalid on xPro V5 controller
« Reply #15 on: September 04, 2023, 22:54:49 pm »
+1
We get the same problem with Mach3 ; the error it return is: "Radius to end of arc differs from radius to start"
The absence of digits beyond a particular number causes an explicit presumption of trailing zeros, and any software should handle that situation.
I spent a lot of time on a GCode (that had no decimals, because written by hand) and that give strange results (or error) in the simulation ...  until I found that it was the problem. It was  with a GCode simulator called NCplot ...
