Author Topic: Number generator (VB script)  (Read 13550 times)
« on: May 03, 2024, 22:42:55 pm »
I often needs to add a lot of numbers in my drawing, to identify parts, to make numbers on rules or meter number and so one.
For this, I often use a "generic" text contained "00" that I copy/paste at the right place or that I dispatch using "array copy", "polar array copy" or the "copy to point list" plugin.
But after the copy is done, I need to manually edit each text object to set the right number.
So I decided to write this small script to automate this job. (because I have a job to do that need around 80 part to renumber)
Select all the text objects to renumber, in the order you want to number them and run the script.
In the script, you can define the variables "start" that will contain the start number, "stepvalue" that will contain the step and "formatstring" that will contain the format to use for the numbers.
' dh42 05/2024
' numérotation incrémental d'une sélection d'objets texte
' incremental numbering of a selection of text objects
sub main
        Dim start As Double, stepvalue As Double, currentvalue As Double
        Dim formatstring As String
        formatstring = "00"
        start = 1
        stepvalue = 1
        currentvalue = start
        Dim s As MText
        If CamBamUI.MainUI.ActiveView.SelectedEntities.Length > 0 Then
            For Each ent As Entity In CamBamUI.MainUI.ActiveView.SelectedEntities
                If TypeOf ent Is MText Then
                    s = ent
                    s.Text = Format(currentvalue, formatstring)
                    s.Update
                    currentvalue = currentvalue + stepvalue
                End If
            Next ent
        End If
end sub
Unzip the attached file and save it in your script folder.
I hope it can be useful for some.
Note VB script are not working on Linux version and on 64bits CamBam Windows version ; If needed I can turn it into a plugin so it will works on all versions.
Re: Number generator (VB script)
« Reply #1 on: May 04, 2024, 19:47:59 pm »
Here's a Python version that works with 64bit version 1
# dh42 05/2024
# numérotation incrémental d'une sélection d'objets texte
# incremental numbering of a selection of text objects
start = 1.0
stepvalue = 1.0
formatstring = "00"
if len(CamBamUI.MainUI.ActiveView.SelectedEntities) > 0:
  for ent in CamBamUI.MainUI.ActiveView.SelectedEntities:
    if ent.GetType().Name == "MText":
      ent.Text = format(currentvalue, formatstring)
      ent.Update()
« Reply #2 on: May 04, 2024, 20:06:14 pm »
Thanks Eddy ;)
(I'm still allergic to python  ;D)
« Reply #3 on: May 04, 2024, 20:43:11 pm »
So am I but I thought I'd give it a try.
