Author Topic: Convex lateral failed  (Read 15441 times)
Offline lima
« on: May 11, 2024, 18:15:00 pm »
Hi everyone Today I performed a convex lateral profile with a 3mm radius and a ball nose cutter, it didn't go well, the paths look ok on the monitor but the cut was as if the cutter radius hadn't been calculated, I should have understood it before. I want to ask, does Cambam take into account the cutter radius in this process? Or is it better to always use end mill cutter? Tomorrow I will add files and photos of the result. Thank you
Re: Convex lateral failed
« Reply #1 on: May 11, 2024, 19:21:22 pm »
Profile cuts do take into account the cutter radius, but they do not know how to account for the change in effective radius of the tool in a 'bowl' type cut with a ball-nose cutter.  Please show us the files.  This was recently discussed in another thread.
« Last Edit: May 11, 2024, 19:24:04 pm by lloydsp »
Offline lima
« Reply #2 on: May 12, 2024, 06:59:54 am »
Thanks for the reply.
Can you send me the link to the topic discussed so I can read it please.
I attach cb file.
Offline lima
« Reply #3 on: May 12, 2024, 07:25:45 am »
Foto
« Reply #4 on: May 12, 2024, 12:08:26 pm »
I attach cb file.
Will this help?
https://cambamcnc.com/forum/index.php?topic=5415.0
« Reply #5 on: May 12, 2024, 12:58:09 pm »
To me it seems CamBam did everything right.
You cannot extend radius of 1 mm to 3 mm depth.
It either should be 3 mm or if 1 mm fillet is desired you offset the outer shape curve -1 mm, apply the convex radius profile to it with depth only 1 mm. The smaller the depth increment, the smoother the shape. In some cases I've gone down to 0.03 mm DI.
I am using this approach to round edges sometimes.
But I also have a limited set of edge rounding cutters - 0.5 to 2 mm radius and they do a good job.
From China :)
https://www.aliexpress.com/item/1005005380899668.html?spm=a2g0o.productlist.main.3.5b2fb04fb04f4b&algo_pvid=90929669-727d-48de-b4c9-2db02b8689d4&algo_exp_id=90929669-727d-48de-b4c9-2db02b8689d4-1&pdp_npi=4%40dis%21BGN%2139.93%2123.96%21%21%2121.60%2112.96%21%40211b801b17155190010311696e39d1%2112000032821289794%21sea%21BG%210%21AB&curPageLogUid=loaQjbl3Kk9g&utparam-url=scene%3Asearch%7Cquery_from%3A
« Last Edit: May 12, 2024, 13:00:49 pm by Dragonfly »
Offline lima
« Reply #6 on: May 12, 2024, 15:34:43 pm »
Thanks everyone, I'll do some practice, for the most important things I think next time I won't hesitate to use CAD. The important thing was to know if the cutter radius is calculated.
