This is my first 3D sculpting job, a mate needs two replacement stool backs. The stock has been cut from pine on the table saw and the corners rounded on the sander. It may not work because of the material but I want to try cutting the scallop on the CNC, there's a 6mm ball nose cutter in the tool list.
Either a simple cylindrical section as indicated by the middle arc, or a saddle type 2way curved surface roughly given by the 3 arcs.
Tips appreciated, eg do this, then this, then this. And I half expect someone to knock out what's needed in 5mins (feel free to show off your skills). I want to learn, but also I want to get this task out the way
thanks,
