Author Topic: 'Boning up' on 3D milling  (Read 11931 times)
Re: 'Boning up' on 3D milling
« Reply #15 on: March 26, 2025, 00:02:31 am »
That's very close, David.  But more important than the actual .stl is the method you showed by which it was drawn.  I may have to alter the dimensions as I go, when I figure out final parts placements inside the hollow cavity (which must also be drawn).
So your method shows me the way.  Thank you!
« Reply #16 on: March 26, 2025, 00:15:17 am »
Re
I just seen that I do an error, the top is ~60 mm of diameter, not 30 ...
A new design with 30mm diam on top and 80mm height instead 50
Edit: and just for info, I warned Andy about the SSL certificate that is over ;)
« Last Edit: March 26, 2025, 00:17:10 am by dh42 »
