Author Topic: Whoa! NEAR Emergency!!!  (Read 23392 times)
« on: September 07, 2025, 11:30:03 am »
Because I purchased a license for CutViewer with CamBam, I have become comfortable with CutViewer, and I rely upon it.
Yesterday, out of the blue, it announced that my 30 day trial had ended, and it ceased to work!
I have migrated my software from XP to Windows 10, and to FOUR different physical platforms since I first purchased my license, so I had to do some searching to find my original license information and instructions.  Thank goodness, I found it (still actually on my CAM computer and backups).
A few minutes later, CV was back to working.
But what in HE!! would cause it to suddenly just abandon a decade-old license?  There's no reason for the registry to have changed -- I do not allow any upgrades or software updates on that machine -- EVER.  It's purely static.  It's not even connected (or connectable) to any network unless I manually plug in a USB network adaptor.  My philosophy is that if it works properly, don't 'mess with it'.  And so far as I can tell, everything else is still working properly.  I did a registry scan afterwards, and couldn't find any corruption.
The license.dat file was still there in the system files, and was an exact copy of my old saved copy.  All I had to do was go through the registration process again.
Re: Whoa! NEAR Emergency!!!
« Reply #1 on: September 07, 2025, 19:06:55 pm »
Just for info, the registry key for CutViewer Mill is:
Windows 64 bits:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MCVREG\CVREG2 (Wow6432Node = soft 32 bits used on 64 bits system)
Windows 32 bits:
HKEY_LOCAL_MACHINE\SOFTWARE\MCVREG\CVREG2
« Reply #2 on: September 07, 2025, 19:08:40 pm »
Thanks, David.  I'll record that with my license info.
Offline airnocker
« Reply #3 on: October 15, 2025, 20:35:07 pm »
Is CV Mill Viewer free now?  Or is what I'm seeing for CV Mill 3.2 something different?
airnocker
« Reply #4 on: October 15, 2025, 21:45:18 pm »
No, CV is still not free, but unfortunately we also can't buy any license since Stan passed away ... now it is an abandonware.
It is possible to extend the trial period by deleting the CVREG2 key (every month)
If needed, I still have the installer for CV Mill 3.2 and CV turn (unavailable on the web now)
Note also that since the V1.0 of CamBam, you need to install a plugin for CutViewer, it is no longer installed by default with CamBam.
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Simu_cutviewer.html
« Last Edit: October 15, 2025, 21:48:26 pm by dh42 »
Offline airnocker
« Reply #5 on: November 22, 2025, 01:31:19 am »
Many thanks David.
airnocker
