I can't figure out how to clear the message "Select objects (use ctrl+click to deselect), then press enter or esc" Once it comes up it stays on top of what ever I am doing until I close the project and reopen it again.
Oh no! Are you getting that message up by right clicking on a machine op and selecting "select drawing objects"? So pressing enter or escape doesn't end the selection? What about clicking the middle mouse button in the drawing? I am having trouble replicating this problem here.
A possible work around, and alternative to the right click - Select drawing objects menu option. You can select multiple objects in the drawing tree, then drag and drop them onto a machining operation to replace the objects that mop uses.
Maybe it is just me, but I am aggravated by the View Pane closing every time your change a selection on the list. Would it be possible to keep it open, add a close selection, or just say to click anywhere on the screen to close the view pane? Sometimes I want to change several items and find it inconvenient to reopen it for each selection.
Sorry George, it's probably just because it's late here, but I'm not sure what you mean by the view pane?
Do you mean the property grid at the bottom left? If so, I'm not sure if this helps, but if you select multiple items in the drawing tree or the drawing view, you can change the value of common properties of all the selected objects in one go.
Any help... or should I just go get some sleep?
