Hi hellocambam
You quote:
My thickness of raw material (wood) is 18.3mm, I designed up to that, in Inventor, but now
when in Cambam I import the STL file into CamBam and state the target depth the same,
i.e. 18.3, when requesting toolpath, I get strange depth, as if far thicker than my real object!
You have to configure your "Autodesk Inventor" correct measures.
See image below.
