Author Topic: STL Extractor (.cb -> .stl)  (Read 10748 times)
« on: January 26, 2012, 18:26:27 pm »
This is not a plugin, but I did not find more appropriate topic for this message
I have lost the STL original  file used in a CB project, and I have only the CB file with the object in it .... and I can't modify it directly in CB (too difficult).
To solve this problem I wrote a standalone utilities who extract 3Dsurface from a .cb file and creates a .stl file that contain all the 3Dsurface objects found in the .cb file
Usage:
Click on "Extraire" to choose a .cb file ; the file is analysed and the extraction start if 3D surfaces are found. The result file is stored in the same directory than the .cb file, with the same name but with a .stl extension.
You can stop the job by "Annuler" (Cancel)
Currently importation of the files produced works well with 3DSmax (and cambam, of course), but not with SolidWorks ; I'll work on that issue. (I know why, but I must revisit my math to solve that).
Feel free to give me a feedback about your tests on other 3D softs.
Insta:
Unpack the archive and use the installer in the folder "Install_CB2STL" (setup.exe).
.Net FramWork 4.0 is required.
Enjoy  ;)
Re: STL Extractor (.cb -> .stl)
« Reply #1 on: January 27, 2012, 01:28:42 am »
David. Awesome idea, not long a go I was looking for a way to do this. Thanks.
« Reply #2 on: January 27, 2012, 15:51:17 pm »
Hello Bubba,
What 3D software you use to read the STL?
The faces (triangles) are correctly oriented after importation ?
Offline lazer
« Reply #3 on: January 27, 2012, 18:01:37 pm »
Hello David
Great job good idea you had.
I'm doing an application for Brazilian and without source code!
People will love it!
lazer = leisure -- Sorry my English
« Reply #4 on: January 27, 2012, 18:18:01 pm »
I try it with a dozen files and that works ... but not with all, I discover a file that won't work with (http://www.cambam.co.uk/forum/index.php?topic=2288.msg13848#msg13848), and I must improve my code.
At the same time, I'm working on a converter to transform the points list given by the mach3 digitizer in a STL file.
« Reply #5 on: January 27, 2012, 19:33:51 pm »
Hi David. The program I use is MeshLab.
http://meshlab.sourceforge.net/
« Reply #6 on: February 12, 2018, 18:27:08 pm »
I know this topic is old...
Just as I need 3D solid that was created in CB converted to STL, the little program David wrote has issues...
It only work part way, because is writing is in French language I have no idea what the message is saying...
« Reply #7 on: February 12, 2018, 18:43:50 pm »
This program only works when a 3D shape has been imported as STL in Cambam. It do not works for 3DS imported files or for 3D surfaces done in Cambam.
« Reply #8 on: February 12, 2018, 18:54:47 pm »
Thanks David. Too bad. :(
« Reply #9 on: February 15, 2018, 22:50:58 pm »
Hi Bubba
There is a way to get any solid geometry out of cb.
1. First you load up the file in cb.
2. Then you apply your 3D mops.
3. Then Simulate it with Camotics.
4. From Camotics use the export function (for the cut surface).
       The quality of the surface  all depends on your mop settings, so if you want a faithful surface
       then you must use a tiny stepover.
 Hope this helps .
« Reply #10 on: February 16, 2018, 02:19:40 am »
Great suggestion. Thank you David.
For now I'm trying to model this in ViaCad, I need to learn how to do this anyway..
Thanks again.
« Reply #11 on: February 16, 2018, 16:53:19 pm »
Hi Bubba
 Hope this helps .
If you crank up the resolution enough in Camotics to get good results you need to have a pretty fast computer to not take all day.  I use the CAMotics plug-in and I have default set to high on my new 4.2ghz quad core, but very high still takes a very long time.
« Reply #12 on: February 16, 2018, 19:09:04 pm »
Also in Camotic, use the toolbar icon "Reduce the cut surface triangle count for more compact export" (at the right side of the "run simulation" button) before to export as STL, if not, you will get a very big STL file that can be unusable as is.
« Reply #13 on: February 17, 2018, 19:11:25 pm »
Hello Bubba
You can use this brand new script to save a selected surface to STL (in the case of your frame, first join the 4 surfaces to obtain an unique object)
Unpack the zip and store the .vbs file in your script folder (or in script2 folder, if you are using the Script Launcher plugin for CB V1.0)
select an unique surface object then run the script.
« Last Edit: February 17, 2018, 19:20:51 pm by dh42 »
« Reply #14 on: February 17, 2018, 23:50:31 pm »
It works! AWESOME JOB! Thanks David. That's what make this group of people special.
 :D ;D
