Author Topic: CamBam on Linux  (Read 286653 times)
Re: CamBam on Linux
« Reply #135 on: September 24, 2015, 16:34:37 pm »
I'm translating the 0.9.8P manual using the Linux Version,  I have to "translate" also some images present in the online Documentation, anyone know if the file used to obtain the  "Toolpath view filter" image is available it is called SimpleBlock on the titlebar?
TIA
Re: CamBam on Linux
« Reply #136 on: September 24, 2015, 17:07:07 pm »
I don't have it, but it is very easy to redo ; it's just 2 pockets ;)
Re: CamBam on Linux
« Reply #137 on: July 10, 2017, 11:24:00 am »
Is the Toolkit (involute gear and timing belt pulley generation) included in the Linux version? I don't see it in my installation.
Offline alex_holden
Re: CamBam on Linux
« Reply #138 on: February 22, 2022, 11:50:30 am »
Just so that's absolutely clear: You cannot Copy/Paste between two running CamBams under Linux.
Sorry to resurrect an ancient topic, but has anyone found a solution to this problem? I've recently been trying out CamBam on Linux (specifically Kubuntu 21.10), and it works fairly well apart from not being able to copy things between two windows, which is something I do quite often as part of my workflow. (I already know about the file merge workaround.) I tried clearing the contents of the KDE clipboard manager widget (which is no longer called Klipper?) as previously suggested, but it didn't make any difference.
Re: CamBam on Linux
« Reply #139 on: February 25, 2024, 22:53:30 pm »
I just discovered that the CamBamPlus_Toolkit.dll is missing in CamBam Linux distribution (Gears and HTD pulleys)
Unpack the .zip and add the CamBamPlus_Toolkit.dll file into your CamBam plugins folder.
Works OK on Linux (tested on Ubuntu 14.04)
Re: CamBam on Linux
« Reply #140 on: February 26, 2024, 11:13:37 am »
I thought it was deliberately not included and never asked why it is missing.
Thanks a lot!   8)
