Author Topic: Thread Milling  (Read 117836 times)
Re: Thread Milling
« Reply #45 on: March 25, 2018, 13:24:03 pm »
I don't see any reference to files being blocked.
Maybe you have to select the file only as on Bob's picture, not the whole folder ?
http://www.cambam.co.uk/forum/index.php?topic=6294.0
I didn't see that.  Good catch David.
Offline Mike F
Re: Thread Milling
« Reply #46 on: April 07, 2018, 21:05:33 pm »
Hi,
I've had a chance to look again and I take on board the previous comments and this time selected only the file, to view the properties. Still no can do. I am using win10 with all the latest updates.
Attached is a screenshot that shows all the plugins I have in my folder plus the ones that CamBam displays, just two!
Bob, it may well be a windows issue but I don't have a scooby what to do about it ;D
Mike
Re: Thread Milling
« Reply #47 on: April 07, 2018, 21:19:30 pm »
ExtrudeSolids appear in the Draw/surface menu
CamBam lathe is the lathe MOP ; menu Machining/Lathe
CutViewer appears in the menu Tools/simulate with cutviewer
The plugins do not necessarily appears in the plugin menu, see the information on the download page of each plugin for more information ;)
Offline sns5400
Re: Thread Milling
« Reply #48 on: April 25, 2021, 08:09:37 am »
I try to install the treadMill plugin but this give me a error on windows 10
There is an error thad i do not understand and problably only the creator can fix this.
Or maybe some other sugestions ?
Re: Thread Milling
« Reply #49 on: April 25, 2021, 08:41:29 am »
Have a look here, it is a windows security problem.
https://cambamcnc.com/forum/index.php?topic=6294.0
Re: Thread Milling
« Reply #50 on: November 19, 2024, 22:18:38 pm »
is there anyone that use CamBam V1 32 bits + the threading mop plugin V1.5.6205.27600 for CamBam V 1.0 32 Bits with Win10 ?, is the MOP  copy/paste working ?
Works well with W7, but a guy have a problem on a W10 machine to copy/paste MOPs and also with the copy/paste format. (also tried in W7 compatibility, non change)
Re: Thread Milling
« Reply #51 on: November 20, 2024, 00:03:27 am »
David, I have rigid tapping so didn't have the plugin,so downloaded it, and made right\left
inside and out threads, works fine for me win 10 CB ver 1.0 32bit.
Copy and pasted all the mops. Ok
Re: Thread Milling
« Reply #52 on: November 20, 2024, 02:38:54 am »
Thanks for the reply ;)
Re: Thread Milling
« Reply #53 on: November 20, 2024, 13:41:21 pm »
Using CB V1 32 bit for Linux.
Thread MOP copy/paste works.
What does not work is copy/paste of Trocho pocket MOP. Only on Linux.  So I have to open a project under Win7 and do several copy/paste of a Trocho pocket MOP to have spare ones while using the Linux version.
