Author Topic: [script] Numerical XY Move + [plugin] NumMove  (Read 80302 times)
Re: [script] Numerical XY Move + [plugin] NumMove
« Reply #195 on: April 03, 2020, 22:24:01 pm »
Lloyd,
Been on the Guinness Foreign Extra ?   ;D I thank you for your comments but as you say I'm just ONE of the helpers here, I do it because it's what I've always done.
I also extend my appreciation to others on the forum.
« Last Edit: April 04, 2020, 11:08:59 am by EddyCurrent »
« Reply #196 on: April 03, 2020, 22:27:32 pm »
Yes V 1.2.0.62 of nummove plugin is working on 64 bits version too ... it's the first plugin I tested after I install CB 64 bits  ;D
Currently, all my plugins except 2 seems to works with CB 64, only ExportSelectionToDXF and RadiusPlugin (fillet/chamfer) needs to be replaced by the very last version to be able to works with 64 bits
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/exportDXF.html
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/fillet-chamfer.html
Have a look here to see what plugins has been updated since Andy publish CB 64 bits
http://www.cambam.co.uk/forum/index.php?topic=4886.msg67387#msg67387
« Reply #197 on: May 22, 2020, 15:23:51 pm »
Hi David,
It's me again :)
I'd really appreciate if you can make NumMove for Linux remeber the last used values like it does under Windows. If possible.
I read recently in the forum that Windows registry method can be applied under Mono. I suppose you use the registry for keeping the plugin state.
Also, under Windows if there is another program running together with CB after closing the plugin window focus moves to that program and not back to CamBam. But this is a minor problem.
« Reply #198 on: May 22, 2020, 15:48:52 pm »
Yep registry works under mono but only with C#, with VB .net the plugin crash if I use registry.
« Reply #199 on: May 22, 2020, 19:03:55 pm »
(These examples are from my Profile2Helix plugin)
public static double steps = 0.0;
// these DO NOT work with Linux
// Save Registry values
Interaction.SaveSetting("CBPlug_Poly2Helix", "Settings", "steps", Params.steps.ToString());
// Load Registry values
Params.steps = double.Parse(Interaction.GetSetting("CBPlug_Poly2Helix", "Settings", "steps", Params.steps.ToString()));
These DO work with Linux
Params.steps = double.Parse(GetRegSetting("CBPlug_Poly2Helix", "Settings", "steps", Params.steps.ToString()));
SaveRegSetting("CBPlug_Poly2Helix", "Settings", "steps", Params.steps.ToString());
private string GetRegSetting(string AppName, string Section, string Key, string Default)
            // attempt to open the subkey
            RegistryKey regKey = Registry.CurrentUser.OpenSubKey("Software\\" + AppName + "\\" + Section, false);
            // if it fails then return Default value
            if (regKey == null)
                return Default;
            else
                try
                    object setting = regKey.GetValue(Key);
                    if (setting == null) return Default;
                    return setting.ToString();
                catch (Exception e)
                    CamBam.ThisApplication.AddLogMessage("Registry Read Error " + e);
                    return null;
        private bool SaveRegSetting(string AppName, string Section, string Key, string Setting)
            try
                // Use CreateSubKey (create or open it if already exits)
                // located in, HKEY_CURRENT_USER\Software
                RegistryKey rootKey = Registry.CurrentUser.CreateSubKey("Software");
                RegistryKey appKey = rootKey.CreateSubKey(AppName);
                RegistryKey sectionKey = appKey.CreateSubKey(Section);
                sectionKey.SetValue(Key, Setting);
                return true;
            catch (Exception e)
                CamBam.ThisApplication.AddLogMessage("Registry Write Error " + e);
                return false;
« Last Edit: May 22, 2020, 19:27:43 pm by EddyCurrent »
« Reply #200 on: May 22, 2020, 20:55:04 pm »
Thanks Eddy ; when time permit I'll have a look to translate this to VB ... and hope this works ..
If it will not work, another workaround is to use global variables so, at least, the value will persist for a CamBam cession and will not be lost each time the plugin is closed.
And the last chance is a separate config file, but I'm not aware of the file convention on Linux, I just know that a Windows file path definition do not works on Linux.
« Reply #201 on: May 22, 2020, 21:07:43 pm »
Path.Combine
This works,
 // use Path Combine for Linux compatibility
 // use our autosave path
            CamBamUI.MainUI.ActiveView.CADFile.Filename = Path.Combine(Params.SavePath, Params.FileName) +"_AutoSave.cb";
