Author Topic: [script] Numerical XY Move + [plugin] NumMove  (Read 80240 times)
Re: [script] Numerical XY Move + [plugin] NumMove
« Reply #30 on: January 19, 2014, 19:34:14 pm »
Hello Armando,
Thanks for this explanations ... but I must take time to understand that.. my knowledge of programming is a little too light currently  ??? ??? I discover VB .net and visual studio  ;)
« Reply #31 on: February 07, 2014, 23:04:31 pm »
A new version of the 'NumMove' plugin that adds rotations functionalities
The rotation center can be at the drawing origin (the cross), at the center of the selection , at the center of each object, or at a fixed position given in the down XYZ text boxes
Be careful, it's only lightly tested
Note that as for other rotation tools of CB, arcs and polylines that contain arcs must be 'arc removed' before rotation around X or Y axis.
With the rotation center set to 'selection', sometimes polyrectangles can cause problem to find the correct center, If you have this problem, convert first the polyrectangles to polylines.
enjoy
« Last Edit: February 08, 2014, 13:48:20 pm by dh42 »
« Reply #32 on: February 08, 2014, 03:58:33 am »
Wow... that almost replaces the transformation matrix, and in a much more intuitive way!
Good deal.
« Reply #33 on: February 08, 2014, 10:22:10 am »
Love it  ;D  David  well done.
« Reply #34 on: February 08, 2014, 12:29:38 pm »
Nice work David. with new plugins written between you and Lloyd, Andy wont recognize his own software when he comeback.. ;) :D ;D ;D
Thanks.
« Last Edit: February 08, 2014, 12:41:41 pm by Bubba »
« Reply #35 on: February 08, 2014, 13:34:02 pm »
Thanks  ;D
There is some other little things that remain to do.
- a better Key validation (cause pb to insert minus sign, and not works with fractional)
- a 'pick' function to pick an object used as center for rotation (to fit the 3 text boxes)
- ..... and the translation auto ... but it's another history I put it aside until Andy gives some help.
- And why not, a 3rd tab for Scaling.
Now I'm being exploring 3D surfaces, and I'll try to do some basic 3D drawing tools ...
EDIT: I add the sources in the previous message.
« Last Edit: February 08, 2014, 13:49:34 pm by dh42 »
Offline BR52
« Reply #36 on: February 18, 2014, 17:53:05 pm »
Hi David,
A present for you!
See here: http://www.cambam.co.uk/forum/index.php?topic=4004.msg27359#msg27359
« Reply #37 on: February 18, 2014, 18:34:13 pm »
Hello Armando,
Hey, nice example  :D  thanks
Offline shorton
« Reply #38 on: March 19, 2014, 15:46:37 pm »
<snip>
enjoy
DAvid, thanks.  Excuse the noob question.  How do I install?  I placed the dll in my plugins folder and restarted, but I can't see that it did anything.
« Reply #39 on: March 19, 2014, 16:54:03 pm »
Yes, it's the correct way.
It must appears in the Edit/transform menu (or shortcut shift+ctrl+M)
http://www.cambam.co.uk/forum/index.php?topic=4064.msg27862#msg27862
Offline shorton
« Reply #40 on: March 19, 2014, 19:10:16 pm »
Thanks, found it.  And I see it apparently moves in steps relative to current position? nice.
« Reply #41 on: March 19, 2014, 20:39:10 pm »
Yes the move is relative to the current position.
In rotate mode, you can select the center of the rotation.
« Reply #42 on: March 19, 2015, 13:18:25 pm »
hello David,
I have found a mistake in your plugin. I wonder that I don´t noticed this before, because this is my "most used" plugin.
The value for "bulge" would have to be inverted.
Please have a look.
« Reply #43 on: March 19, 2015, 16:54:41 pm »
Hello Ralf,
Yes, It's very strange ; and in the code I use the same "transformation matrix" followed by a "apply transformation" ...
I'll investigate ...
Done ... the problem is that after each rotation, I "apply transformation" .. if you do the same manually with the transformation matrix and you apply the transformation after a 90° rotate, the problem is the same, the circles are modified.
In the plugin, I must apply transformation after each move/rotate, because if not, the value returned for the object center is wrong until the transformation has not been applied ... and if I run a second rotation that goes wrong ...
Note: in the plugin, the problem appears only if you rotate twice 90° but not for a 180° rotation.
Ah Ah, you are also working on a phone ... same for me .. (Iphone6 and 6+)
« Reply #44 on: March 20, 2015, 09:00:16 am »
hello David,
yes thats a mobile. I have to finish 30 of them from PMMA till next week. Like the design in attachment. The most work are the polished buttons at the sides.
Yes, that it is. If I have a polyline the radius change the direction after "apply transformation" .
This not occurs with a polyrectangle.
