Author Topic: [Script - Plugin] Flatten  (Read 5559 times)
« on: December 23, 2012, 17:22:01 pm »
A new very little VBscript.
It set to 0 the Z coordinate of each selected polyline.
' aplatir (flatten)
' set all Z values to 0 in selected polylines
sub main
if view.SelectedEntities.Length > 0 then
if typeof ent is Polyline
ent.Flatten()
end if
next ent
view.RefreshView()
end if
end sub
« Last Edit: May 02, 2014, 19:32:37 pm by dh42 »
Re: [Script - Plugin] Flatten
« Reply #1 on: May 02, 2014, 19:34:09 pm »
I just convert my flatten script to a plugin.
I appears in the Edit/polyline menu (main menu)
« Last Edit: January 05, 2016, 15:45:17 pm by dh42 »
« Reply #2 on: May 02, 2014, 22:56:47 pm »
Thanks David the plugin works nice, Your effort is appreciated.
Dave.
« Reply #3 on: May 01, 2016, 20:08:17 pm »
New version 2.0 of the plugin.
Now it works on all 2D objects (except splines) and it can also flatten the points in a point list as for a polyline, it also move the other 2D objects to Z = 0.
undo is also now supported on this version
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/flatten.html
« Reply #4 on: May 02, 2016, 16:48:46 pm »
Re
And the source code (VB .net)
