Author Topic: Resize Line  (Read 3219 times)
Resize Line
« on: February 08, 2013, 20:51:00 pm »
Hello guys  ;)
Here is a new script in VB that allows resizing lines and polylines with only one (straight) segment.
The script show the point that must be fixed with a little circle and let you the choice to change this fixed point.
A requester show the size and asks for the new size. If negative values are used, the line is drawn in opposite direction.
Just a problem that I can't solves, the lines retains their ID (I changes the point list), but no luck with polylines, if I modify the points, it does not work, I must delete and re create a new polyline ... and of course it have a different ID. (just a problem if the polyline is already used by a MOP)
Edit: I forget to say ... it work only in 2D ;)
http://www.screencast.com/t/CBfISQS0EC
« Last Edit: February 10, 2013, 15:57:47 pm by dh42 »
Re: Resize Line
« Reply #1 on: February 10, 2013, 18:07:21 pm »
Just for info:
Work on 0.9.8 L, N RC7, N RC7b, but not with N RC4  ;)
« Last Edit: February 10, 2013, 18:24:51 pm by dh42 »
