Author Topic: Nesting Doc  (Read 17336 times)
Nesting Doc
« on: June 23, 2013, 18:52:18 pm »
I (try to) translate my French nesting doc in English, here is the result.
http://www.atelier-des-fougeres.fr/Cambam/Aide/English_addendum/Nesting.html
This is now integrated in the regular manual
http://www.cambam.info/doc/dw/1.0.0/cam/nesting.html
« Last Edit: July 22, 2018, 00:13:48 am by dh42 »
Re: Nesting Doc
« Reply #1 on: June 23, 2013, 19:21:00 pm »
Thank you!  Your grasp of English is far better than mine of French!
As (if) time permits, I will attempt to put that in the common American English vernacular, but I must say that, for the most part, you did a yeoman job of it!
There is very little to change, and then, only in the use of particular words unique to American English, and as pertains to case and tense, which varies between the Latinic and Germanic languages.
Re: Nesting Doc
« Reply #2 on: June 23, 2013, 19:26:01 pm »
I also use intensively the translator !!  ;)
Offline Jeff_Birt
Re: Nesting Doc
« Reply #3 on: June 24, 2013, 01:02:54 am »
Very nice write up on nesting!
Re: Nesting Doc
« Reply #4 on: November 17, 2015, 16:37:52 pm »
I use nesting all the time, and that is a very good write up.  I learned a couple things that I did not know or had wrong about how it works as well.  Thank you.
Re: Nesting Doc
« Reply #5 on: November 17, 2015, 18:10:06 pm »
Wow! You did a beautiful job on this! I haven't used nesting yet but I'll will definitely refer to this when I do.
Re: Nesting Doc
« Reply #6 on: November 17, 2015, 19:12:12 pm »
Thanks ;)
Offline WireCut
Re: Nesting Doc
« Reply #7 on: December 27, 2015, 17:18:49 pm »
Hi David,
seems that this link
is not reachable.
I has been moved to China and I do not know if this page is really not reachable, or in not reachable from here.
Leo
Re: Nesting Doc
« Reply #8 on: December 27, 2015, 18:09:01 pm »
It work for me ; maybe due to your location (but why !!! I don't know)
I just turn it into a PDF quickly ;)
Offline newlinuxuser
Re: Nesting Doc
« Reply #9 on: December 27, 2015, 18:09:33 pm »
From Italy the link works correctly.
Offline lucky phil
Re: Nesting Doc
« Reply #10 on: January 20, 2016, 20:50:00 pm »
Hi David
great work on your document, making it an easier decision for me to purchase CamBam when there is documents available like this.
Philip
Re: Nesting Doc
« Reply #11 on: January 20, 2016, 21:11:22 pm »
And Phil, if you think the documentation is great (which it is!), just wait 'til you see how much support you get here on the forum, and how quickly you get it.
(you just got a taste of that)
Offline homebuiltncrouter
Re: Nesting Doc
« Reply #12 on: March 12, 2019, 19:05:57 pm »
I've just read the document and watched a very good video about nesting. I have a problem that may not have a solution but I'm hoping there is. I need to turn one of my parts ninety degrees in order to fit all parts on a sheet of 4x8 ply. Is there a way of doing this. I'd much rather use nesting than copy and paste.
Re: Nesting Doc
« Reply #13 on: March 12, 2019, 19:24:48 pm »
Sometimes I make a copy of the part, then rotate and reposition it so less material is wasted. Then make MOP for both objects and nest them as a single block. As a result they are nested as pairs.
Offline jk
Re: Nesting Doc
« Reply #14 on: March 14, 2019, 18:15:52 pm »
Actually it's quite easy to rotate a single copy while nesting.
Bring up the Nesting Collection editor (click ellipsis next to the Nesting Items).
Select the copy in question or add another one.
Set it's location to 0,0,0 to simplify rotation.
Open it's Transform, fill Rotation, Z, 90 degrees, apply.
The copy would be rotated 90 degrees around origin.
Position it to place by dragging the red triangle.
Note: you may also mirror this copy be setting Scale -1 in Transform.
« Last Edit: March 14, 2019, 18:23:47 pm by jk »
