Author Topic: Bring CutViewer up to date  (Read 19109 times)
« on: July 23, 2013, 13:05:00 pm »
Cutviewer has some basic deficiencies.  For instance, it cannot handle the 'default' arc mode of CB.
This is a chore, because one must have a different post for cutviewer than for one's physical machine.
Andy, will you ask for some improvements that will allow us to set up CV for a particular set of modes, so we don't have to switch posts?  Sometimes that causes errors, when one forgets to switch back before actual machining.
Re: Bring CutViewer up to date
« Reply #1 on: July 23, 2013, 18:09:57 pm »
Have you look at the _gcode.nci settings for CutViewer (located in the CutViewer program files folder)?
In this text file are a couple of settings...
IJkformat_abs
and
IJkformat_incr
The CutViewer help file has more detail on all the available options (under the Customization section), but the main ones of interest are...
Center      ( same as arc center mode absolute in CamBam )
and
center-start      ( arc center mode incremental )
Note, set the _abs and _incr variables to be the same... the absolute/incremental suffix refers to the linear move mode (G90/G91).
I hope that helps a bit in getting a unified post processor.
« Reply #2 on: July 23, 2013, 18:48:36 pm »
Hmmm... I guess I should blush.  It's been so long since I installed CV, I'd completely forgotten about those.
I wonder why he doesn't allow them to be configured in his setup, though...
Thanks, Andy; as always, you come to the rescue!
