Author Topic: [VB script + plugin] Invert selection  (Read 6026 times)
« on: August 09, 2013, 23:29:22 pm »
Here is a script to invert the selected shapes.
'invert selection - dh42 2013
sub main
dim ent as Entity
dim ID as integer
dim rep as boolean = false
        CamBamConfig.Defaults.ReloadTreeAfterScript = false
' store data for actual selection
dim oldselection as ArrayList = new ArrayList()
for each ent in view.SelectedEntities
oldselection.Add(ent)
next ent
'select all
view.SelectAllVisibleGeometry()
dim invertselect as ArrayList = new ArrayList()
'scan all the objects
rep = scanID(ent.ID, oldselection) ' test if ID exist in old selection
if rep = false then 'not found
invertselect.Add(ent) ' add the object to the new list
end if
next ent
view.Select(invertselect)
end sub
function scanID( ID as integer, oldsel as ArrayList ) as boolean
'scan the old selection, if ID match, return true, else false
dim ent as Entity
for each ent in oldsel
if ID = ent.ID then 'match found
return true
exit function
end if
next ent
return false 'no match found
end function
« Last Edit: January 02, 2014, 20:21:38 pm by dh42 »
Re: [VB script] Invert selection
« Reply #1 on: September 10, 2013, 13:00:11 pm »
A little correction to the script, because the objects are selected in the view but not in the tree.
(4 th line in the main sub)
« Reply #2 on: September 10, 2013, 13:48:16 pm »
Um... wouldn't you want to make that '=true', so the tree selection occurs after the script?
Or does that refresh the whole tree to the unselected state?
« Reply #3 on: September 10, 2013, 14:21:49 pm »
Explanation from our Jedi master here  ;)
http://www.cambam.co.uk/forum/index.php?topic=1972.msg11881#msg11881
Note that without this line of code, the objects are selected, we can move it, but if you try to delete or cut it, nothing happens.
« Reply #4 on: September 10, 2013, 15:23:12 pm »
Ah!  So glad I asked!
« Reply #5 on: January 02, 2014, 19:40:38 pm »
And the new version as plugin.
The new item is located in the Edit menu and has a shortcut -> Ctrl I
Enjoy
« Last Edit: February 07, 2014, 16:55:29 pm by dh42 »
Re: [VB script + plugin] Invert selection
« Reply #6 on: February 07, 2014, 16:57:23 pm »
A little change, I just see that the Ctrl + I is already used for 'convert to region'  :-[
The new version use now Shift+Ctrl+I
