Author Topic: V-Engrave Plugin  (Read 356102 times)
Offline pstemari
Re: V-Engrave Plugin
« Reply #15 on: August 13, 2013, 05:18:49 am »
> You need Add Reference: "System.Runtime.Serialization"
That's already in there.  Without it you can't save at all.
I'm not sure what the cut & paste issue is.  If the save issue above is just a single attribute I probably just missed setting the flag.
Offline pstemari
« Reply #16 on: August 13, 2013, 06:17:02 am »
Ok, issue 9 is fixed.
Build b0002 has been uploaded to http://v-engrave-plugin.storage.googleapis.com/v-engrave-plugin-latest.zip
« Reply #17 on: August 13, 2013, 08:15:00 am »
Wow! Thank you for your brilliant work on this Paul.
I haven't check this, but the copy & paste issues may be due to not having a...
[Serializable]
attribute on your MOPVEngrave class.
Any serialized custom classes used within the MOPVEngrave also need to be marked as serializable.
I hope this helps and thank you again!
Offline BR52
« Reply #18 on: August 13, 2013, 12:20:31 pm »
The correct address is:
https://code.google.com/p/v-engrave-plugin/wiki/Downloads
Has no function change the properties of the MOP  ???
Example diameter and angle of the tool is the same old value.
Note the comment from David and Andy.
« Reply #19 on: August 13, 2013, 13:49:47 pm »
no change for me (and it was already a b0002 in the download, but say b0001 in the "about"), the value of Path step size is not saved.
EDIT: Ok,  :-[ I download the wrong file (v-engrave-plugin-latest.zip) the right link is v-engrave-plugin-b0002.zip ...  and the problem is solved, but it show always "b0001" in the "about" (and also in the Windows properties/version panel)
« Last Edit: August 13, 2013, 15:02:18 pm by dh42 »
Offline BR52
« Reply #20 on: August 14, 2013, 11:05:04 am »
Hi David,
I just want some help finding BUGs.
You made ​​a video here:
http://code.google.com/p/v-engrave-plugin/issues/detail?id=12
        Make a video showing this BUG:
In the properties window in MOP VEngrave1 with the right mouse tries to copy.
pstemari, the file "v-engrave-plugin-src-b0003.zip" is empty  ???
« Reply #21 on: August 14, 2013, 12:41:17 pm »
Hello Armando,
No problem for me to download the b0003 ; I add it in attachment
It solves the problem with MOP copy.
Offline BR52
« Reply #22 on: August 14, 2013, 13:33:00 pm »
David thank you very much,
OK worked great but the file "v-engrave-plugin-src-b0003.zip" is empty.
« Reply #23 on: August 14, 2013, 14:02:55 pm »
Yes, same for me, I had not seen that it was the source file that you want  :-[
« Last Edit: August 14, 2013, 14:07:28 pm by dh42 »
Offline pstemari
« Reply #24 on: August 14, 2013, 16:37:48 pm »
Sorry about that.  Should be good now.
Offline pstemari
« Reply #25 on: August 19, 2013, 06:13:19 am »
I just uploaded b0004.  This includes fixes for issues:
3Overshoot on smooth corners
4Max depth/cutter diameter is not implemented
6Default step size is too small for mm-based projects
7Wrong MOP icon
8Can't copy a V-engrave MOP
9V-engrave MOP spécific datas are not saved in .cb file
12ToolPath display bug if Stock surface <> 0
16Infinite loop/bad toolpath
« Reply #26 on: August 19, 2013, 17:49:17 pm »
Is only the V 90 deg cutter used with this plugin? Is any thought of adding a V60 deg cutter as well. Smaller test would look better cut with V60. Thanks.
« Reply #27 on: August 19, 2013, 18:13:08 pm »
Huh?  Just set your own angle!  90-degrees is the default setting.  You can change it.
Offline pstemari
« Reply #28 on: September 16, 2013, 04:45:27 am »
I just uploaded b0005.  Nothing major, some fixes for the z-position at the beginning and end of each cut.  The behavior with rapids should be better.   See Issue 18 for details.
Offline BR52
« Reply #29 on: September 16, 2013, 17:42:32 pm »
Hi
The problem is in the "post processor", I created a "post processor" see attached.
Second, I create in library tool, a tool see picture attached.
« Last Edit: September 16, 2013, 17:44:15 pm by BR52 »
