Dear Edddy
I am attaching a test file (using VEngrave 1.4)
(1) On loading, Depth Increment is set to 0 and Max Depth to Infinity, tool diam to 0.0, tool tip diam = 0.0, 60 deg Vee: Result: Fail - computation goes on forever: This config should give the same result as V1.2, i.e. a single full depth cut.
(2) Though I am now also seeing Error icons in Max Depth and Depth Increment params at times, these must be edited to values values (say 1,10) to get a result
(2) Change depth increment to 2: Get error message: MaxDepth must be greater than zero, and get Error icon in Params list
(3)Change Max Depth to +10: now gives correct results.
There seems to be some issues with Depth increment, providing both Depth increment and Max Depth > 0.0 then seems to be OK.
Or, what I have I done wrong?
