hello,you can make this also with the v-engrave plugin.You need the letter, you draw a second polyline with the offset function and a third polyline with the half of the distance of the first offset.The letter and the first offset line you convert in to a region. After you use STR+U on this region.To cut "inside" the letter you set the stock surface lower then the stock. As lower you set the stock as more you cut to the middle of the letter.The second polyline with the half distance you need for the pocket.In the attached file you see how I do this.You need a cutter with a flat v-angle and a large diameter.ralf
It just requires something to parse the generated G code file to find the extremes of Z-----------You have that in CB, Eddy.LLoyd
