Author Topic: [VB script] Round the coordinates of the polyline points  (Read 10442 times)
« on: September 16, 2013, 17:42:54 pm »
This script allow to round the coordinates of the points in a polyline to the given number of decimals.
Only XYZ coordinates are rounded, the bulge value is not affected.
The number of decimals is set to 5 by default, but you can change it in the code ; change the value in the line:
   dim nbdeci as integer = 5
Only polylines are modified.
'Round the coordinates of points in a polyline
' to the given number of decimals.
' DH42 - 16/09/13 - V1.00
sub main
CamBamConfig.Defaults.ReloadTreeAfterScript = false
dim ent as Entity
dim pli as Polyline
dim plitem as PolylineItem
dim NewPoint as point3F
dim blg as double
dim ct as integer
dim nbpoints as integer
dim rep as string
app.Clearlog()
'ask for nb of decimals
rep = inputbox("Number of decimals","Round points coordinates",trim(str(nbdeci)))
if rep <> "" 'if not canceled
nbdeci=val(rep)
'if reply is out of range
if nbdeci < 0 or nbdeci > 15
msgbox("Nb of decimals must be between 0 - 15")
exit sub
end if
'scan selected entities
for each ent in view.SelectedEntities
if typeof ent is Polyline 'if polyline
pli = ent
if pli.Closed = True 'if polyline is closed nb points = nb segmentss - 1
nbpoints = pli.NumSegments-1
else
end if
for ct = 0 to nbpoints 'scan all points in the polyline
plitem = pli.Points(ct)
' store the rounded values of the current point in a temp variable (Point3F)
NewPoint.x = Math.round(plitem.point.x,nbdeci)
NewPoint.y = Math.round(plitem.point.y,nbdeci)
NewPoint.z = Math.round(plitem.point.z,nbdeci)
' store the Bulge (not rounded)
blg = plitem.Bulge
'remove the current polylineitem
pli.Points.RemoveAt(ct)
' add the modified polylineitem at the same position
pli.InsertSegmentBefore(ct, new PolylineItem(NewPoint,blg))
next
end if
next
view.ClearSelections()
view.RefreshView()
end if
end sub
Thanks to pstemari for is help ;)
I (want) use this script when I've problem with leadmove (wrong direction), or missing toolpath in pockets, I discover that mostly, if I round the values of the points, the bug go away ... but it's long to do manually ... ;D
« Last Edit: September 16, 2013, 19:30:39 pm by dh42 »
Re: [VB script] Round the coordinates of the polyline points
« Reply #1 on: September 17, 2013, 13:04:10 pm »
Hello David,
thank you for the script.
I never see that rounding the dezimal places brings a different if a mistake occures.
I try yesterday with tangent leadins and pockets to get a difference between the original file and used with the script.
Can you please upload a file with some mistakes that can be correct with the script.
Offline jeramenemafraise
« Reply #2 on: September 17, 2013, 13:56:50 pm »
bonjour David,
J'ai fais un essai, mais je ne trouve pas d'arrondi dans les coordonnées X et Y de la polyligne que j'ai sélectionnée.
j'ai du faire une erreur ?
dommage car c'est un utilitaire sympa.
Yves.
« Reply #3 on: September 17, 2013, 14:29:22 pm »
Hello David,
Hello Ralf,
Unfortunately, I've not keep the files that cause pb, and I can't redo the bug ....(of course, never when I want)
« Last Edit: September 17, 2013, 14:34:07 pm by dh42 »
« Reply #4 on: September 17, 2013, 14:33:16 pm »
bonjour David,
Yves.
http://screencast.com/t/JubXDLHxs
« Reply #5 on: September 17, 2013, 15:31:52 pm »
Re
I try to retry the same job that give the lead bug, but nothing to do, that works each time ...  ::) I move the shape more and more ... and always no bug !!
We never find bug when we are looking for it, we find it only when work is in a rush !  ;D ;D
« Reply #6 on: September 17, 2013, 15:53:54 pm »
Ah Ah !! I got it !!
see in attachment.
« Reply #7 on: September 17, 2013, 19:32:01 pm »
Strange this.
If I drag the left "bad" rectangle with the mouse 0.05mm on x-axis to the left the lead in switches. But if I translate the same value with the transformation matrix it is still wrong.
It looks like a black hole in the drawing window. If I drag the rectangle in every direction a little bit the leadin works.
Thank you for this, I never see this before
« Reply #8 on: September 17, 2013, 19:48:59 pm »
Another strange thing is also that in the real drawing there is 12 identical parts aligned, and all have the same problem until I change the two coordinates 36.4000007629395 by 36.4 (as in the shape at the right)
