Author Topic: bug with 3D scanline toolpath and Back Side 0.9.8P and older  (Read 1424 times)
« on: October 16, 2013, 17:35:22 pm »
Hello Andy,
because it is the time now to eliminate all the heavy bugs I have here one again. It is a very old bug that has to extinct now on the way to the v1
If I use scanline toolpath and Back Face, the toolpath are only correct if the part is centered in Z direction or lower then z=0.
Now I have a part that is aligned with the bottom on Z=0, I have to set the Back Face Zero Z to 5mm (hight of part is 5mm)
This works with waterline toolpath, but if I switch to scanline toolpath I get the bug. With the scanline toolpath it works from centered part down, but not if the Back Face Zero Z is set to a positiv value.
Back Face should work with all toolpath in the same way.
