I haven't posted in the drag-knife script thread recently because I had to solve some mechanical problems. Some of them - self inflicted
The problem was that with the corrected tool trajectories there were no visual result when trying on foil. I knew that I slightly overdid the knife holder hole on the carrier I made and there was some play. So I decided to make a new carrier. Several days went drawing, making some parts, then again drawing and changing the design. Finally a new carrier (to held in the spindle chuck) came to being and I was very pleased with it. Now I can change the spring and adjust its tension and the moving part slides on two pins with no play.
But the result on foil was again a failure.
So I took the Roland knife holder and had a look inside. It appeared that trying to have the heel cap on as much thread as possible I've adjusted the knife too deep and its shaft (2.5 mm OD) got out of the ball bearing leaving there the thin neck ( ~1 mm) and the knife was rocking unsupported radially.
While putting and taking out things something got stuck, I applied some brute force without much thinking and there came out a piece of the brass capsule where I knew the magnet was inserted, the magnet itself and in addition - three tiny steel balls and a tiny steel cup.
Left it for the night for my frustration to pass and in the morning, after some pondering and head scratching I understood why there was no second bearing in there. The cup and the balls formed a kind of axial bearing and the conical shaft end lying in the center of the thee balls tripod.
But I needed a new capsule and decided to make one. Had no suitable brass piece nor tools for it. So I went for Acetal (Delrin). And I made it. I am really starting to love my machine which I built in home garage conditions.
Here's what the rear end support looks like. The red part is the magnet.
