Author Topic: Pvc cable carrier  (Read 80819 times)
Offline mk22000
Re: Pvc cable carrier
« Reply #15 on: November 17, 2013, 14:08:40 pm »
here is the file,what is wrong?
« Reply #16 on: November 17, 2013, 16:15:07 pm »
As Lloyd asked.. "What machine?  What post-processor?"
The info is needed in order to be able to help you.
« Reply #17 on: November 17, 2013, 16:29:50 pm »
MK,
First, start with the very basics.  You have not selected a post-processor.  Without one, CB cannot properly convert machining paths to g-code.
Click on the Machining tab, scroll down to "post processor", and select Mach3.  Then re-save your .cb file, and re-generate the g-code.
Offline mk22000
« Reply #18 on: November 17, 2013, 20:53:42 pm »
ok i will try this,thank you lloyed i did not really know where to choosh this options,now i will!
« Reply #19 on: November 17, 2013, 21:16:15 pm »
MK, just a caution...  We still do not know what machine or controller you use... Mach3 was only a guess... it could be a different post-processor.
Offline mk22000
« Reply #20 on: November 18, 2013, 22:26:33 pm »
sorry about that,i use mach 3 on 3 axis cnc..
« Reply #21 on: November 19, 2013, 16:16:28 pm »
If you only have one machine and it is Mach 3 driven you should take the time to setup your default template to Mach 3.  That way you don't forget.
Offline JerryHRoss
« Reply #22 on: December 06, 2015, 20:59:11 pm »
Attached cable chain files have been modified to load with CamBam version 0.9.8P.
« Reply #23 on: December 06, 2015, 21:09:27 pm »
Heh!  Jerry!
You're rapidly becoming a "resource"! <G>
« Reply #24 on: December 06, 2015, 21:24:57 pm »
Rather than going through a heap of random files, it would be more useful if you wrote a script or plugin to do the conversion.
