Author Topic: Script Shortcut Buttons  (Read 5047 times)
Online csirocnc
  • Howell V4
« on: February 08, 2014, 09:21:46 am »
Hi All
Has anyone seen or made (hint hint)  "user buttons" that can be on the tool bar and defined to open selected scripts.
Cheers
Paul
1st CamBam Licence sale
in Australia
Re: Script Shortcut Buttons
« Reply #1 on: February 08, 2014, 16:54:58 pm »
Um.... many plugins plant buttons on the toolbar!
A plugin is just a script wearing a tuxedo.
« Reply #2 on: February 09, 2014, 18:27:12 pm »
Kinda like politicians and pigs.
Offline ThisAmplifierIsLoud
  • Jam it !
« Reply #3 on: November 19, 2018, 09:37:48 am »
The question old, but I want to ask again.
Is it possible to start a python script just by clicking a simple button
instead of script-open script-select the script-F5 ?
Best regards
Bernhard
best regards
Bernhard
« Reply #4 on: November 19, 2018, 09:53:15 am »
  • Jam it !
« Reply #5 on: November 19, 2018, 10:04:41 am »
Eddy, I guess you´re never sleeping...  ;D
THX for your extreme answer.
I´d rather had just a nice button to quick-start my magic script.
No SIMPLE way ?
best regards
Bernhard
« Reply #6 on: November 19, 2018, 10:29:20 am »
Make it a plugin then you can do that
« Reply #7 on: November 19, 2018, 11:02:47 am »
namespace YourNamespace
    public class YourMainClass
        public YourMainClass()
        public static void InitPlugin(CamBamUI ui)
            // Create a new menu item in the top Plugins menu
            ToolStripMenuItem mi = new ToolStripMenuItem();
            mi.Text = "Your_MenuText";
            mi.Click += new EventHandler(plugin_clicked);
            mi.ShortcutKeys = Keys.Control | Keys.Shift | Keys.M;
   mi.ShortcutKeyDisplayString = "Ctrl + Shift + M";
            ui.Menus.mnuPlugins.DropDownItems.Add(mi);
        public static void plugin_clicked(object sender, EventArgs e)
            YourMainForm iface = new YourMainForm();
            iface.Owner = CamBam.ThisApplication.TopWindow;
            iface.Show();
This is the base for a plugin, the part that put the plugin name in the plugins menu.
I assembled some code (the shortcut parts is from another plugin)
To create a button you have to populate the InitPlugin(CamBamUI ui) with the proper code to create a button,
At the moment I don't rember the proper code, as i haven't had the nedd to crete one  but generally it involves:
1) adding some icon that became the button
2) creating and adding a button to the ToolBar
3) adding an action that is executed when the button is pressed
The  usual thing is to write a plugin that do what you want, but it has to be written in C# or maybe in VB# (some other guys have writtens some plugins in VB# notably dh42 if i'm remeber well)
I doubt there is no way to make a button in a script, as the scripts are not auto-loadable if I remember well, for this someone have developed the launcher plugin, as noted in this thread.
Carlo D.
« Last Edit: November 19, 2018, 11:09:19 am by onekk »
  • Jam it !
« Reply #8 on: November 19, 2018, 11:08:00 am »
Thank you very much, but this is too complicated for me.
Just to save a few mouse-clicks I don´t want to
- Install Visual Studio
- Learning some C#
I prefer the KIS-principle : Keep it simple !  ;D
best regards
Bernhard
« Reply #9 on: November 19, 2018, 13:48:49 pm »
The problem here is that a button has to exist BEFORE the script is started, that implies something else has to run first to make the button available.
With that in mind I think the "Script Launcher" plugin is your best option.
« Last Edit: November 19, 2018, 13:51:02 pm by EddyCurrent »
« Reply #10 on: November 19, 2018, 14:56:46 pm »
While we are at it there is a missing keyboard shortcut, not speak about a button for one of the most frequently used CB functions - Transform -> Align.
  • Jam it !
« Reply #11 on: November 20, 2018, 14:56:51 pm »
Try this plugin; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Script_launcher.html
At first I want to apologize. I meant "extreme fast answer" instead of "extreme answer".
The Script launcher works like a charm, it´s only 1 mouse-click more than a launch button.
THX !
Bernhard
« Last Edit: November 21, 2018, 21:04:12 pm by gmoo »
best regards
Bernhard
