Author Topic: VERY rough Conic Helix script  (Read 3411 times)
« on: June 06, 2014, 13:12:59 pm »
here: http://www.cambam.co.uk/forum/index.php?topic=4209.0
PS... Bob L... this will cut pipe threads, too! <G>
(no leadins/outs yet, but it could be made to have them)
PS... there was a bug that made the start point of the helix the first step in, instead of the real start point.
  (bug was in the original 'boingy')  It's fixed there, and here:
' Conic Helix.vbs
' CamBam vbscript
' With credits to 10 Bulls for the idea from "Boingy"
   dim turns as single
   dim start_diameter as single
   dim end_diameter as single
   dim depth_increment as single
   dim strAnswer as string
   dim direction as single
sub main
   start_diameter=val(Inputbox ("Smaller diameter? "))
   end_diameter=val(Inputbox ("Larger diameter? "))
   turns=val(Inputbox("Number of turns? "))
   depth_increment=val(Inputbox ("Depth change per turn -- negative =-Z, or down "))
   direction=val(Inputbox("Direction to turn -- -1=CCW, 1=CW"))
   direction=direction*-1
   dim p as polyline =   MakeConicHelix()
   doc.add(p)
end sub
function  MakeConicHelix as polyline
   dim start as single   = 0         ' in radians
   dim finish as single = turns*2*pi   '30*pi      ' in radians
   dim steps as single   = 500      ' number of steps
   dim radius as single = start_diameter/2
   dim startz as single = -1*depth_increment*turns
   dim endz as single   = 0
   dim radius_step as single = (end_diameter-start_diameter)/(steps*2)
   dim x as single = 0
   dim y as single = 0
   dim z as single = startz
   dim th as single = start
   dim dt as single = (finish-start)/steps*direction
   dim dz as single = (endz-startz)/steps
   '// Get the drawing ready to draw
   dim p as Polyline = new Polyline
   '// Play da loop
   for i as short = 0 to steps
      x = radius * math.cos(th)
      y = radius * math.sin(th)
      p.Add(x,y,z)
      radius=radius+radius_step
      z = z + dz
      th = th + dt
   next i
   MakeConicHelix = p
end function
« Last Edit: June 06, 2014, 14:37:54 pm by lloydsp »
Re: VERY rough Conic Helix script
« Reply #1 on: December 21, 2014, 19:56:17 pm »
Here's an adjustment to the script above that allows you to specify the number of segments per turn, in order to smooth the line.
' Conic Helix.vbs
' CamBam vbscript
' By AMDlloydsp, with credits to 10 Bulls for the idea from "Boingy"
   dim turns as single
   dim smooth as single
sub main
    smooth=val(Inputbox("Smoothing factor (number of segments per turn) recommended 100 per turn as a compromise."))
   doc.add(p)
end sub
   dim steps as single   = turns*smooth      ' number of steps
   dim x as single = 0
   dim y as single = 0
   '// Play da loop
      p.Add(x,y,z)
      z = z + dz
      th = th + dt
   next i
   MakeConicHelix = p
end function
« Last Edit: December 21, 2014, 20:00:47 pm by lloydsp »
« Reply #2 on: December 21, 2014, 21:57:14 pm »
Hello Lloyd,
Cool, added to the list ;)
