Author Topic: Curved surface script  (Read 181796 times)
« on: June 12, 2014, 06:59:25 am »
I have developed a CamBam script (VBS) that will create a circular singular curved surface (in the vertical plane) - based on the sloping line script at http://www.cambam.info/ref/script.sloped-lines. So far it appears to work quite well.  It uses a similar set of parameters as the sloped line script:
  • A start point and an end point
  • A width, or 0 for a single cut
  • A depth of cut at the end point
  • There are options to create an Engrave MOP with some default parameters set, and a G-Code file if required.
The top of the curve is assumed to be a Z=0.  By using a ball mill and adjusting the step over distance rather smooth curved surfaces can be cut.
The script can be down loaded from the link below.
I would be interested in receiving suggestions for improvements or if any bugs are found.
thanks
Note: The latest version (1.0.2)  of the CurvedSurface Plugin (described later) is also attached here.
New Version 2.0.3 now available for testing
New version 2.0.4 now available
« Last Edit: July 23, 2020, 08:31:05 am by GeoffreyGRoy »
Re: Curved surface script
« Reply #1 on: June 12, 2014, 12:47:12 pm »
Well done Geoff,  Works as advertised.
Dave.
« Reply #2 on: June 12, 2014, 21:33:40 pm »
Geoff,
Very nice. How about a  version to do this kind of part.  This is an 13.5" diameter flange that is being cut to fit against a 120" diameter tank.  I also cut one to go inside.
« Reply #3 on: June 12, 2014, 21:50:16 pm »
Gary,
Unless there's some sort of distortion in the photo, that looks like the inside one...???
Re: Sperical surface script
« Reply #4 on: June 12, 2014, 23:59:53 pm »
I have also created a script to generate spherical surfaces with the top of the sphere at Z=0, and a specified depth at a given radius.  If this is also of interest then it can be downloaded from the link below:
It uses a similar set of parameters as the curved surface script.
Again comments and bugs are appreciated.  Note that V1.00 did have some minor bugs.
« Last Edit: June 14, 2014, 08:30:16 am by GeoffreyGRoy »
« Reply #5 on: June 13, 2014, 11:05:37 am »
Gary, one other word about that.
His script already does that kind of part -- in a sense.  It creates half of the surface on which to map your other features.  You can mirror the surface he creates, and it becomes a barrel-shaped surface like you want.
« Reply #6 on: June 13, 2014, 20:09:35 pm »
Gary,
Lloyd,
You are right. I took the photo to show an engineer at my previous employer that I could do these on my home built machine.  We used to send these out to get done in different size flanges and different radiuses all the time.
« Reply #7 on: June 13, 2014, 20:16:42 pm »
I have also created a script to generate spherical surfaces with the top of the sphere at Z=0, and a specified depth at a given radius.  If this is also of interest then it can be downloaded from:
http://www.cadplan.com.au/blog/index.php?entry=Creating-Spherical-Surfaces-with-CamBam
Geoff,
Can it do a spherical pocket?  I have a job to do with 12 spherical pockets for a bearing ball to sit in to build a 3D Delta style printer.
« Reply #8 on: June 13, 2014, 20:22:18 pm »
Sounds good Lloyd, I'll have to try that.
You know back in the 80s and 90s I did quite a bit of programming. I still do PLC programming and watching you guys here makes me want to give it a try again. As soon as I stop working 60 hours a week.
« Reply #9 on: June 13, 2014, 20:48:05 pm »
Gary,
You wouldn't have to modify the program.  Just create one of his "half barrel" shapes, then use CB to reflect it and join it to the other half.
« Reply #10 on: June 13, 2014, 22:44:07 pm »
You know CB can already extrude a surface from a polyline right?  Then you can rotate it and position it as needed.  Am I missing something?
« Reply #11 on: June 13, 2014, 23:04:07 pm »
No, Bob.  You're right.  This just makes it more 'natural', and in fewer steps (with subsequent necessary confirmations).
Re: Curved surface scripts
« Reply #12 on: June 15, 2014, 07:25:19 am »
Following the comments and some further testing I can now release three scripts for constructing 3D circular surfaces, two updated ones and one new one.  In each case some bugs have been fixed, and in particular a facility has been added to specify a stepover for roughing and a stepover for finishing.  This can reduce cut times significantly while not compromising finish quality.  Also, it is now possible to produce a finish cut only allowing for a separate cut for roughing, either using the same script, or some other strategy.
More details can be found on my web site at http://www.cadplan.com.au
Comments and feed back most welcome.
« Reply #13 on: June 15, 2014, 11:11:05 am »
Geoff,
Thanks!  That's good stuff.  I have a customer project with a need for the spherical pocket script coming up next month.
« Reply #14 on: June 22, 2014, 00:23:56 am »
I have now added another script to my small collection -to create a curved pocket using the same approach as the others.  In this case the curve is like a horizontal cylinder pocket by specifying:
  • The depth at the centre line
  • The distance from the centre line to the edge (i.e. half the length)
  • The width of the cut of the cylinder shape
Please advise if any bugs are found.
« Last Edit: June 22, 2014, 01:39:52 am by GeoffreyGRoy »
