Author Topic: Curved surface script  (Read 181797 times)
Re: Curved surface script
« Reply #120 on: May 04, 2020, 12:51:33 pm »
Hello Geoff
Thanks for this new release.  ;)
Some texts are not translatable (see photo)
just for info to update the website, is this new version still running on CB 0.98 or it works only with 1.0 ?
« Last Edit: May 04, 2020, 12:56:49 pm by dh42 »
« Reply #121 on: May 05, 2020, 01:32:11 am »
Thanks David, I will fix in the next release - I am waiting for some more feedback/bugs to be found.
This version is for V1.0 and 64 bit (probably works for 32 bit - not tested).
« Reply #122 on: May 05, 2020, 12:07:41 pm »
Hi Geoff,
I'm pretty sure my settings are off that is why can't get this plugin to work. When clicking the run button it does create the statistics, new layer, but does not create the solid surface etc...
screen shot and CB file attached.
Bubba
« Reply #123 on: May 06, 2020, 00:47:43 am »
Dear Bubba
The main problem is that the Accuracy setting is set at 2" in your image Capture.JPG.  As I indicated in a previous message this default value is wrong for Imperial units.  It should be of the order of 0.02".  This bug will be fixed in the next release.  But, you can change this value (see TestBa.png in the attachment).
Also as I previously explained the Profile shape needs to be carefully managed.  In your file the Polyline shape contains Arcs.  I have updated your model (in the attachment) as follows:
(a) Copied Polyline(8) to a new Layer as Polyline(1)
(b) Remove arcs form Polyline(1) with an accuracy of 0.001
(c) Rotate Polyline(1) by 90 deg about X-axis
(d) Apply Transformations to Polyline(1)
(e) Select Polyline(1)
(f) Launch the Plugin and set the Accuracy to a small value.
The results can then be seen in TestBb.png.  I have also included the updated CB model as above.
I will be posting the updated version of the plugin in a few days, I am just waiting to see if I get any more bug reports.  As I also explained previously there is another bug that you may see in the results as parts of your Profile shape lie exactly on the X,Y plane - you may see some artifacts in the result - these can be resolved by moving the Profile shape up by 0,.001"
I hope this helps
Offline ThisAmplifierIsLoud
  • Jam it !
« Reply #124 on: May 06, 2020, 07:11:04 am »
Thanks Geoff, for this wonderful plugin.
I really like it.
I have a wish : Wouldn´t it be nice to store and load the settings ?
best regards
Bernhard
« Reply #125 on: May 06, 2020, 10:05:47 am »
The field "Path Shape" should be "Path Shape ID" where only the ID number of the path shape should be entered.
« Reply #126 on: May 07, 2020, 00:00:51 am »
Dear Edddy
Thanks for the comment, I will change the caption to "Path Shape [ID]".  I think it is still useful to include "Polyline", "Arc" or "Circle" (it can only be one of these) as this offers a confirmation of the selected Path shape.
Dear gmoo
The next release will save parameter values between CamBam sessions
« Reply #127 on: May 07, 2020, 04:39:17 am »
Dear Bernhard
Concerning saving settings, I can do it. Which option would be best?
(a) Automatically save the current settings, with an option to restore the defaults.
(b) An explicit Save/Restore option in the plugin dialog
I am trying to use the Properties.Settings object as provided in C#, at the moment I can figure out how to have a single set of user defined Settings, though multiple sets may be possible.
  • Jam it !
« Reply #128 on: May 07, 2020, 06:36:51 am »
Hi Geoff,
explicite files would be great, So I can handle with different "templates".
best regards
Bernhard
  • Jam it !
« Reply #129 on: May 07, 2020, 07:26:36 am »
BTW...with the help from your plugin I can make these nice little bowls
from cheap fire-wood.
Best regards
Bernhard
« Last Edit: May 07, 2020, 07:29:20 am by gmoo »
best regards
Bernhard
« Reply #130 on: May 13, 2020, 08:30:15 am »
Dear All
I am attaching vers 2.0.1 that fixes all (I hope) of the issues raised above.  Please test and let me know what I have missed.
There has been a number of significant changes from v2.0.0, please check the User Guide for details.  I have found a number of bugs that result from very particular geometric conditions, and added the capability to save the parameter settings across CamBam launches for convenience
  • Jam it !
« Reply #131 on: May 13, 2020, 13:18:11 pm »
Hi Geoff,
played around a little with spherical surface and found bugs at the load/save settings area.
- Center Point XY, Radius, from/to angle is always 0 after loading
- load directly after store setting raises exception :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at CurvedSurfacePlugin.CurvedSurfaceUI.setData()
   at CurvedSurfacePlugin.CurvedSurfaceUI.loadSettingsB_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
CamBam
    Assembly Version: 1.0.7364.41821
    Win32 Version: 1.0.7364.41821
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/CamBam.exe
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.3761.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CamBam.CAD
    Assembly Version: 1.0.7364.41819
    Win32 Version: 1.0.7364.41819
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/CamBam.CAD.DLL
CamBam.Geom
    Assembly Version: 1.0.7364.41817
    Win32 Version: 1.0.7364.41817
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/CamBam.Geom.DLL
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
CamBamLathe
    Assembly Version: 1.1.7364.1589
    Win32 Version: 1.1.7364.1589
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/CamBamLathe.dll
CamBamPlus_Toolkit
    Assembly Version: 1.1.7364.1587
    Win32 Version: 1.1.7364.1587
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/CamBamPlus_Toolkit.dll
CBubble
    Assembly Version: 9.0.0.0
    Win32 Version: 9.0.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/CBubble.dll
CurvedSurfacePlugin
    Assembly Version: 2.0.1.0
    Win32 Version: 2.0.1.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/CurvedSurfacePlugin.dll
ExcellonIO
    Assembly Version: 1.5.7364.1595
    Win32 Version: 1.5.7364.1595
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/ExcellonIO.dll
FileMerge
    Assembly Version: 1.5.5745.22477
    Win32 Version: 1.5.5745.22477
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/FileMerge.dll
Grid Manager
    Assembly Version: 1.0.2.0
    Win32 Version: 1.0.2.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/Grid%20Manager.dll
HeightMapPlugin
    Assembly Version: 1.3.7364.1595
    Win32 Version: 1.3.7364.1595
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/HeightMapPlugin.dll
Inlay Toolpath
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/Inlay%20Toolpath.dll
PolylineSmooth
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/PolylineSmooth.dll
Profile2Helix
    Assembly Version: 7.1.0.0
    Win32 Version: 7.1.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/Profile2Helix.dll
script_launcher
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/script_launcher.dll
Snappy
    Assembly Version: 8.8.0.0
    Win32 Version: 8.8.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/Snappy.dll
TextOnPolyline
    Assembly Version: 2.3.0.0
    Win32 Version: 2.3.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/TextOnPolyline.dll
Texturize
    Assembly Version: 1.10.0.0
    Win32 Version: 1.10.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/Texturize.dll
VoronoiBuilder
    Assembly Version: 1.0.7.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/plugins/VoronoiBuilder.dll
OpenTK
    Assembly Version: 3.1.0.0
    Win32 Version: 3.1.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%201.0/OpenTK.DLL
System.Drawing.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
best regards
Bernhard
« Reply #132 on: May 13, 2020, 13:40:02 pm »
It's easier to use the Registry for save/load settings, it works with Linux too.
I use the form opening and form closing events for that.
Of course you only get the last settings rather than a choice of others.
« Last Edit: May 13, 2020, 13:41:58 pm by EddyCurrent »
  • Jam it !
« Reply #133 on: May 13, 2020, 14:05:02 pm »
No, Sir,
IMHO the registry is the WORST place to store the settings.
Using simple file file I can
- have a much as I want
- move, copy, delete, whatever I want to
- give them free names
- port to another computer
- system platform independant
best regards
Bernhard
best regards
Bernhard
« Reply #134 on: May 13, 2020, 17:28:32 pm »
I agree with @gmoo, i have used simply ini file stored in Cambam plugin directory, or even in another place, simply, readable with a simple text editor, portable.
Hi to all.
Carlo D.
