Author Topic: SCRIPT SUMMARY  (Read 158365 times)
Re: SCRIPT & PLUGIN SUMMARY
« Reply #30 on: February 13, 2015, 21:43:36 pm »
Updated
ball bearing calculator, paraboloid script, shapes plugin, squircle plugin, snap toolbar
« Reply #31 on: March 21, 2015, 15:24:15 pm »
Updated with: 3DConnexion SpaceMouse plugin, Rotate Keys [Linux plugin], WayPoints 2
« Reply #32 on: March 31, 2015, 14:32:04 pm »
Updated with: Unmachined Areas and open/closed polyline selector (both scripts)
« Reply #33 on: April 03, 2015, 21:18:05 pm »
updated with: Bottom-up threading of a hole marked by a circle
« Reply #34 on: April 10, 2015, 13:40:16 pm »
excellon file handler updated
« Reply #35 on: April 10, 2015, 21:21:17 pm »
« Reply #36 on: April 20, 2015, 12:51:35 pm »
Numeric Polyline, Fast Open/Convert, Hypotrochoid script, Custom CAM toolbar and Inlay Calculator added
« Last Edit: April 20, 2015, 13:29:07 pm by dh42 »
« Reply #37 on: April 26, 2015, 16:40:32 pm »
Polyline Add points added
« Reply #38 on: April 30, 2015, 19:25:02 pm »
Dotted Lines, File Merge plugin, Sized Lines added
« Last Edit: April 30, 2015, 19:37:40 pm by dh42 »
« Reply #39 on: May 09, 2015, 13:41:15 pm »
SVG import plugin, Polyline Move multiple points and Parametric Shapes Script added.
« Reply #40 on: May 09, 2015, 15:39:25 pm »
I'm not sure Dotted Lines should be added yet, I would hate for someone to spend a lot of time on a drawing only to find it can't be saved !
I'm currently working on the problem.
« Reply #41 on: May 09, 2015, 16:12:50 pm »
Hello Eddy,
Hum, yes, you are right .. I added it before we discover the pb ... and I forgot to remove it .. I'll do that ;)
« Reply #42 on: May 24, 2015, 19:10:57 pm »
CBubble Entity information popup box and Fillet-Chamfer plugins added
« Reply #43 on: May 24, 2015, 19:24:05 pm »
David, here's some text for the plugin web page;
CBubble
Usage:
With the letter ' i ' key pressed, move the mouse cursor over an object.
A popup box will appear showing information about that object.
If the object is a Polyline, the Start Point will be highlighted by a small dot.
If you are in the Polyline Edit mode where all the points are shown as small squares,
the popup box will still appear as normal and the small square at the Start Point will
also be highlighted with a small dot.
« Last Edit: May 24, 2015, 20:51:17 pm by EddyCurrent »
« Reply #44 on: May 24, 2015, 20:49:12 pm »
Thanks for the texts ;)
Select the polyline object so it's highlighted (one object only) one or multiple objects can be selected
I reload the last version and I can't select more than one polyline ; if it's the case I get a message box 'Please Select One Item Only'
