Author Topic: Arrows & Dim  (Read 94738 times)
Arrows & Dim
« on: August 03, 2014, 22:50:41 pm »
A 'crude' beta version of a plugin designed to do arrows and dimensions.
Warning ! works only for V 0.9.8 P of Cambam
The plugin adds 3 items in the 'plugin' menu:
- Arrows: Draw an arrow ; click the start and end point to draw an arrow. The size and angle is given in the bottom window when finished.
- Dimension: Draw an arrow and allow to place a dim text
- Dimensions and Arrows - settings: shows the following window:
* you can choose between 5 arrows terminations or no arrow for each ends of the line.
* you can define the width and height of the arrow and also use a scale factor. the scale factor is a quick way to change the arrow termination size without changing the ratio width/height.
* you can choice the font and size used for the dim text. If scale is checked, the height is equal to Arrow height x scale. If size is checked, the size given below is used.
* If text centered is checked, dim text is automatically placer at the center of the arrow, if unchecked, you can place the text by mouse with a 3th clic. (if Esc is used at this moment, the text is placed to the center)
* If fixed is checked, number are formatted with fixed length.
revisions
version 1.0.0.7 : first beta version published (04/08/2014)
version 1.0.0.8 : (04/03/2015) make the arrows data persistent after Cambam is closed.
version 1.0.0.9 : (07/03/2015) repeat the arrow command until ESC or middle MB is clicked
version 1.0.1.0 : (08/03/2015) add a very basic dimension tool
version 1.0.1.2 : (08/03/2015)
- bug corrected: the arrow scale is not taken in account for texte size
- bug corrected: an undo is created when abort edit is clicked
- add font name, size and scale management
- add a setting for number of decimals
- memorize windows position between sessions
version 1.0.1.3 : (11/03/2015)
- shortcut added: CTRL D -> Dimensions, CTRL H -> Arrows, CTRL K -> settings
version 1.0.1.4 : (12/03/2015)
- add text placement by mouse
- add fixed decimals option
- add an option to choice between mouse placement or auto centered
version 1.0.1.5 : (20/07/2015)
- bug correction (remove handler after usage)
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/arrowdim.html
« Last Edit: July 20, 2015, 15:43:51 pm by dh42 »
Re: Arrows & Dim
« Reply #1 on: August 03, 2014, 23:03:41 pm »
KRUNCH! (Sound of metal on metal... Sorry!)
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeLoadException: Could not load type 'CamBam.CAD.MeasureEditMode' from assembly 'CamBam.CAD, Version=0.9.4878.23990, Culture=neutral, PublicKeyToken=null'.
   at ClassDimArrow.DimArrowPlugin.Get_points()
   at ClassDimArrow.DimArrowPlugin.Arrow_clicked(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3655 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
CamBam
    Assembly Version: 0.9.4878.23992
    Win32 Version: 0.9.4878.23992
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/CamBam.exe
    Win32 Version: 2.0.50727.3645 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.3644 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CamBam.CAD
    Assembly Version: 0.9.4878.23990
    Win32 Version: 0.9.4878.23990
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/CamBam.CAD.DLL
CamBam.Geom
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/CamBam.Geom.DLL
System.Xml
    Win32 Version: 2.0.50727.3654 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Design
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
8x6dfssv
we_hbrvh
ArcsCenters
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/ArcsCenters.dll
ArcText
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/ArcText.dll
BottomViewToolbarAddins
    Assembly Version: 1.0.5112.25486
    Win32 Version: 1.0.5112.25486
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/BottomViewToolbarAddins.dll
CamBam.CAD
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CamBam.CAD.dll
Microsoft.JScript
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3643
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
Microsoft.Vsa
    Win32 Version: 8.0.50727.3053
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Vsa/8.0.0.0__b03f5f7f11d50a3a/Microsoft.Vsa.dll
OpenTK
    Win32 Version: 1.0.278.44921
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/OpenTK.DLL
CamBamLathe
    Assembly Version: 1.1.4878.23997
    Win32 Version: 1.1.4878.23997
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CamBamLathe.dll
m-eznld9
CamBamPlus_Toolkit
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CamBamPlus_Toolkit.dll
CamBamPrintV3200
    Assembly Version: 3.1.1.3
    Win32 Version: 3.1.1.3
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CamBamPrintV3200.dll
Centroid
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Centroid.dll
CurvedSurfacePlugin
    Assembly Version: 1.0.0.10
    Win32 Version: 1.0.0.10
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CurvedSurfacePlugin.dll
CutViewer
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/CutViewer.dll
Demo_Plugin
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Demo_Plugin.dll
DimArrow
    Assembly Version: 1.0.0.7
    Win32 Version: 1.0.0.7
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/DimArrow.dll
ExcellonIO
    Assembly Version: 1.3.5002.22522
    Win32 Version: 1.3.5002.22522
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/ExcellonIO.dll
HeightMapPlugin
    Assembly Version: 1.3.4878.23997
    Win32 Version: 1.3.4878.23997
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/HeightMapPlugin.dll
Hypocycloid
    Assembly Version: 1.0.4028.20405
    Win32 Version: 1.0.4028.20405
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Hypocycloid.dll
MakePartStock
    Assembly Version: 2.0.5.2
    Win32 Version: 2.0.5.2
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/MakePartStock.dll
Microsoft.VisualBasic
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
NumMove
    Assembly Version: 1.1.0.8
    Win32 Version: 1.1.0.8
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/NumMove.dll
Polygon
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Polygon.dll
SelectByObjectType
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/SelectByObjectType.dll
SelectUnused
    Assembly Version: 1.0.0.3
    Win32 Version: 1.0.0.3
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/SelectUnused.dll
Translations
    Assembly Version: 1.0.4244.16006
    Win32 Version: 1.0.*
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Translations.dll
VEngrave_Plugin
    Assembly Version: 0.0.0.8
    Win32 Version: 0.0.0.8
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/VEngrave_Plugin.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
bwt4dnnt
ViewToolbarAddins
    Assembly Version: 1.0.4753.731
    Win32 Version: 1.0.4753.731
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/ViewToolbarAddins.dll
Zoom
    CodeBase: file:///C:/Program%20Files/CamBam%20plus%200.9.8/plugins/Zoom.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: Arrows & Dim
« Reply #2 on: August 03, 2014, 23:36:13 pm »
Hello Lloyd
Arggg !!
Works on XP pro 32bit and W7 64 bit with rev 0.9.8 P, but not with 0.9.8 N ... ;D ;D
(P works well and solve little bugs of N version)
I adds the source if you want try to do a N version for you ..
« Last Edit: August 03, 2014, 23:38:02 pm by dh42 »
Re: Arrows & Dim
« Reply #3 on: August 03, 2014, 23:40:24 pm »
Thanks, David.
No time right now.  The only reason I have not upgraded to P is because I'm on a downhill slide to finish a product, and can't afford anything unexpected.
I'll look at it, and upgrading to P in two weeks.
BTW... thank you for that!  I waste a lot of time drawing little dimensioning elements.  That will be quite useful.
Re: Arrows & Dim
« Reply #4 on: August 04, 2014, 00:28:06 am »
+1  :D
Offline lockie
Re: Arrows & Dim
« Reply #5 on: March 03, 2015, 22:02:27 pm »
Thanks for all the good people on this forum that work so hard to make things easier for the rest of us. I do not want to rush anybody here but I would still love to see this for version N. This would be a very handy plugin.   Thanks Al
Re: Arrows & Dim
« Reply #6 on: March 03, 2015, 22:05:40 pm »
Lockie,
Unless you have a business-critical reason to NOT upgrade to "P", just do it.  So far, I've not heard any objections to it over "N", and I will soon upgrade (I never have yet finished that project!).
Offline lockie
Re: Arrows & Dim
« Reply #7 on: March 03, 2015, 22:56:17 pm »
OK Thanks Lloyd will do I just wondering how do I save all of my N work with upgrade?? Thanks Al
Re: Arrows & Dim
« Reply #8 on: March 03, 2015, 23:04:41 pm »
Lockie, I ALWAYS make a copy of all my work before upgrading anything.  Just copy your work folders to another temporary folder NOT in the CamBam path before starting.
That said, I've never lost anywork upgrading CamBam (but your mileage may vary!!!).
Re: Arrows & Dim
« Reply #9 on: March 04, 2015, 08:15:59 am »
Hi All
Works here win7 32bit p version
Re: Arrows & Dim
« Reply #10 on: March 04, 2015, 08:26:47 am »
Ha ha! what a clown I am, I hadn't even tried it, it also works for me in version P Win7 64bit.
And furthermore, I like it !
Edit:  ??? lost my marbles a bit today, I thought the jist was , won't work in version P but it was the other way round.
« Last Edit: March 04, 2015, 15:17:51 pm by EddyCurrent »
Re: Arrows & Dim
« Reply #11 on: March 04, 2015, 13:42:15 pm »
The same here. ;D
Offline lockie
Re: Arrows & Dim
« Reply #12 on: March 04, 2015, 15:11:11 pm »
Downloaded to version P windows 7 32 bit works well. The original measurement tool changed, it only allows 1 measurement now then closes even when OK is pressed. no bigge good tradeoff for the dimension tool.  Thanks to all.    Al
Re: Arrows & Dim
« Reply #13 on: March 04, 2015, 15:17:22 pm »
Does anyone know why it won't work on version P ?
Is it because of this ?
Yes, If I well remember, Andy has done some change in the measure tool in P rev (the measure text is shown on the measure line)
@Lockie: before upgrading your cambam version, in cambam, menu tools/browse system folder to open the folder where CB save the posts, tools, etc, and save all the file and folder (it contain your styles, tools, posts ...)
P works well and solves some little bugs existing in N
Re: Arrows & Dim
« Reply #14 on: March 04, 2015, 15:19:33 pm »
David, will you be adding the dimensions options any time soon ?
