Author Topic: Shapes to Points List  (Read 18888 times)
« on: November 06, 2014, 16:52:55 pm »
I just finish a little script that allow to copy one or more drawing object (of any type) to the matching position defined by the points of a point list.
Before running the script, select a point list then the other objects to distribute. The point list must be the first object in the selection.
The center of the drawing (teh cross) is used as center point for the objects to copy
a video here
http://www.screencast.com/t/47nvAjBGg42
The VB code
' shape to pointlist dh42 - 2014
' create a copy of the selected shape at each position of the point list
'select a point list and any drawing object - the point list must be the first selected object
'the center of the drawing is used as center for the objects to copy
sub main()
if view.SelectedEntities.Length > 1 then
dim first as boolean = true
dim pl as PointList
for each ent as Entity in view.SelectedEntities
'first entry must be a pointlist
if first = true then
if typeof ent is PointList then
pl = ent
first = false
else
msgbox("The first selected object must be a pointlist !")
exit sub
end if
else 'other entries after the point list
MoveShapeToPl(ent,pl)
end if
next ent
end if
end sub
Sub MoveShapeToPl(ent as entity, p as PointList)
'Copy and move a copy at each point in the point list
dim e as entity = New Entity()
'for each point in the pointlist
for each pt as Point3F in p.points
'copy the entity
e = ent.clone()
activelayer.Entities.Add(e)
'move the copy to the current point location
e.Transform.Translate(pt.x,pt.y,pt.z)
' apply transformation
if e.ApplyTransformation() then
   e.Transform = Matrix4x4F.Identity
end if
view.RefreshView()
next pt
End sub
Edit see here for last version
http://www.cambam.co.uk/forum/index.php?topic=4449.msg62026#msg62026
« Last Edit: December 09, 2018, 07:14:42 am by dh42 »
Re: Shapes to Point List
« Reply #1 on: November 06, 2014, 18:50:46 pm »
Nicely done David!
« Reply #2 on: November 06, 2014, 22:15:47 pm »
Ah, an "object snap-to-point" function!  Nice!
« Reply #3 on: November 06, 2014, 22:26:19 pm »
hello,
Yes, I need this function today ; I assume that I can use engraving + nesting to point list, then Toolpath to geometries,... but no luck Toolpath to geometries only convert the source toolpath, not the nested toolpath.
When I get time, I'll transform it in plugin and maybe I'll add some options like rotation, scale or autonumber for text ...
I can't retrieve the link to the API webpage in the cambam website ; it has disappeared ?? ... until I remember that I've the same link in the French doc !! ::)
http://www.cambam.info/doc/api/
« Reply #4 on: November 06, 2014, 23:31:35 pm »
Yes this was a good idea, I can think of at least one instance lately where this script would have
saved quite a bit of time.
Thanks David
Re: Shapes to Points List
« Reply #5 on: November 07, 2014, 00:51:34 am »
A great addition to CB.
As always.
 Thank you David. ;) ;D
Offline dsnellen
« Reply #6 on: November 08, 2014, 17:42:26 pm »
Pretty cool. Thanks.
« Reply #7 on: December 09, 2018, 07:08:02 am »
A small addition to this script.
Now, it allow to define a rotation and/or scaling value to each copy (except the first one)
for scaling : a scale of 1.1 means 110% scaling ; the first copy is not scaled, the second is scaled 10% wider, the third 20% (of the initial size)
for rotation, negative values = rotate CW, positive = rotate CCW ; the first copy is not rotated
For using with a pointlist generated on a circle ( Divide Geometry &  Step Around Geometry) the first point is always at the right hand side, aligned on the X axis and the path turn CCW when used on a circle or a circle converted to a polyline. If you revert the polyline before the points creation, the start point is at the same place, but the path turn CW
« Reply #8 on: December 09, 2018, 18:33:39 pm »
Merci ! excellent addition.
« Reply #9 on: April 09, 2020, 00:02:38 am »
I just turn this script to a plugin for CB V1.0 (only) 32 & 64 bits
Not tested on Linux at this time ... (if someone test it on linux, a feedback would be appreciated ;))
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Copy2pointlist.html
« Reply #10 on: April 10, 2020, 03:06:36 am »
« Reply #11 on: April 10, 2020, 07:48:32 am »
It's a good plugin.
