Author Topic: Error in Squirrel tap file  (Read 36876 times)
Offline crash
« on: July 06, 2007, 01:39:53 am »
Another thing that happens is if I delete a profile or a pocket operation it will cause a fatal error in the program and shut it down.
I tried to import a large DXF file and my computer locked up so hard I had to do a power off shutdown. It is 2 rings of text created with DeskEngrave. I thought it was just a fluke so dummy tries it again! Locked it up same as before. You could smell tire smoke!! I tried it in DesKam and it opened OK. I have used DesKam for 4 or 5 years. Don't like it but its all I have. I am not being critical of your work just trying to help. I really want CamBam to suceed.
I use MACH3 now. It is a great program. Art's support is second to no one. I started with KCAM 3. KCAM was jerky but it has a feature that I still use. You can view your Gcode plot just like MACH3 but if you see an error you can take the mouse and draw a line across the error and it will hi-light that line of code. Neat feature.
I have rambled too much. Hope you understand my ramblings
Jerry
PS txt file is really a TAP file but I couldn't post a Tap file
Mach3 running Gecko 210 drivers@ 48 VDC
Offline Doanwannapickle
Re: Error in Squirrel tap file
« Reply #1 on: July 06, 2007, 02:23:52 am »
Hi,
I loaded your tap file into Mach and it ran fine on my machine.  I'm using version 2.065.  I think you'll need to be a bit more specific as to what the problem is with this file.
As to the large dxf file with all the text, you didn't post it so I couldn't look at it.  But, if I were to make a wild guess, you perhaps didn't wait long enough.  I've seen people post this same problem with other CAM programs.  Turned out the text contained so many entities, it took a very long time for the program to digest it.
Hope this helps,
Walt
« Reply #2 on: July 06, 2007, 11:07:21 am »
Binky strikes again!
Well I load it into Mach 3 (R2.0.065) and everything looks OK, but on the status it says...
"THIS IS WHERE THE ERROR IS"
But it doesn't appear to show any error lines.  ???
I loaded it into Metacut Utilitites and no errors were reported.
Please feel free to send me any DXF files to look at.  You should be able to send them as a private message to me if there's anything you don't want to post publicly.
Alternatively you can email them to me at 10bulls at gmail dot com.
Offline crash
« Reply #3 on: July 06, 2007, 11:53:07 am »
I got messed up posting that. The first half of the post is missing. It loads fine.  Delete the line (THIS IS WHERE THE ERROR IS). I put that in there. When I try to run the code I get the following error:
         Radius to end of arc differs from radius to start on Line number #13
 I use  in my setup I J mode is incremental.
I downloaded and installed  Version R2.0.081.  I was using 1.84. It didn't help.
« Reply #4 on: July 06, 2007, 14:36:41 pm »
Art @ Mach has a good explanation for the behavior that you're seeing.
Go here: http://www.machsupport.com/forum/
and use search term: Radius to end of arc differs
The first result should resolve your issue.
Walt
