Author Topic: 3DConnexion SpaceMouse plugin  (Read 341278 times)
Re: 3DConnexion SpaceMouse plugin
« Reply #255 on: July 30, 2024, 21:48:18 pm »
Update to drivers, v10.9.0
Tested on Windows 11 64bit with CamBam 1.0 (64bit) and 0.9.8
Offline tau
« Reply #256 on: October 05, 2024, 18:01:44 pm »
Hello Eddy,
3DConnexion updated again to 10.9.1.
Can you pls do your magic again?
Thx
« Reply #257 on: October 05, 2024, 19:44:52 pm »
Update to drivers, v10.9.1
Offline tau
« Reply #258 on: October 06, 2024, 08:25:50 am »
Thx!
« Reply #259 on: December 18, 2024, 11:52:48 am »
Update to drivers, v10.9.2
If anyone wonders why I keep updating these drivers, it's because each time 3DConnexion make an update to their drivers it breaks this CamBam plugin.
I have to recompile the plugin so that it works again with CamBam.
If the only software you use with a 3D mouse is CamBam, there is little to gain from updating the 3DConnexion drivers, however in my case I also use it with Rhino CAD software so I keep it up to date.
« Last Edit: December 18, 2024, 12:01:08 pm by EddyCurrent »
« Reply #260 on: January 14, 2025, 21:01:28 pm »
Update to drivers, v10.9.3
« Last Edit: January 28, 2025, 16:10:21 pm by EddyCurrent »
Offline tau
« Reply #261 on: May 22, 2025, 15:55:53 pm »
Hello Eddy,
any chance for another Update to v10.9.5....?
Thx!
« Reply #262 on: May 22, 2025, 18:29:02 pm »
Update to drivers, v10.9.5
Offline tau
« Reply #263 on: May 22, 2025, 22:48:27 pm »
Thank you!...
Offline tau
« Reply #264 on: June 27, 2025, 04:44:32 am »
... v10.9.6 appeared
« Reply #265 on: June 27, 2025, 09:34:57 am »
Update to drivers, v10.9.6
Offline tau
« Reply #266 on: June 28, 2025, 14:32:46 pm »
Thx, Eddy!
Offline tau
« Reply #267 on: July 14, 2025, 10:25:40 am »
Eddy,
even though i had no problems in the past, the current version allows me to set the file permissions correctly (allowing a dll to be used from external sources... and once set this item option dissappears in the properties windows od the plugin), cambam will not load the plugin properly (exception fault... see Echo from cambam after being loaded).
Any clue what might cause this? I hope it's not any update from MS causing this....
« Reply #268 on: July 14, 2025, 12:35:30 pm »
I'm using the latest Win11 update and the plugin is working fine.
It might be to do with an update and .NET also David said this, https://cambamcnc.com/forum/index.php?topic=10703.msg79743#msg79743
The latest plugin was compiled before the last Win update so I shall do it again and post a new copy.
Edit. Just noticed my Visual Studio wants to update so I shall do that first.
Edit. All updated, recompiled plugin attached.
Tested on Windows 11 with latest updates at time of posting here, also latest updates of Visual Studio 2022
In the plugin dll details it will show as version 10.9.61 (it won't let me use letters)
but in CamBam it will show as version 10.9.6b
« Last Edit: July 14, 2025, 13:04:30 pm by EddyCurrent »
« Reply #269 on: August 14, 2025, 06:51:44 am »
Update to drivers, v10.9.7
